Script for naming saves of series of images, as well as button?
jonascsjonascs Posts: 35
edited January 2022 in Product Suggestions
Hi!
I'm not a script writer, but I do render alot, and would love a feature where DAZ helps with saving file names for a series of renders.
Something for all Renpy game dev's and comic book creators out there.
Ex. If I render a series of images called: Image1, Image2, Image3, etc I would love a feature where I could just click a button by the Image name for it to add prefixes and suffixes right there.
So, if I render "Image" I just set the suffix 1,2,3 in what ever checkbox there would be and it would name it "Image1" the next would automatically be called "Image2" etc.
Also a button where the file is automatically saved with the name of rendered file would be awesome right there where the Image name menu is, would be awesome.
Is this doable?
I sent a mail to DAZ six months ago, but nothing has happend except that the person recieving the mail sent it to dev's.
What do you think?
  • Moved to Product Suggestions as it is not a post about scripting.
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
  • juvesatrianijuvesatriani Posts: 561
    edited January 2022
    Not sure if this will answering your question about script . But I`m always use freebie FAST STONE image viewer to batch rename just like how you want to do . It also offer much more options in one batch including resizing -reduce only quality ( but keep the size) and quick edit connection with your 2D image editor . It also fast even in low spec machine
    Post edited by juvesatriani on
  • cridgit said:
    It is super easy in DAZ Script to auto-increment render file name, add scene filename etc. The problem is the part about adding a button or editing Render settings. As soon as you touch the DAZ UI you're out of DAZ script land and into plug-in land (to my knowledge).
    Looking at the API here http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/object_index/rendermgr_dz I can see you're able to retrieve getLastSavedRenderPath but not set it to anything. This might require a plugin which generally has more access to DAZ Studio internals than a script.
    This is a good idea though.
    The path is set in Render Settings, niot Render Manager (which can be scripted - see the samples). I'm not sure about some of the other comments.
    edited May 2022
    Redacted
  • OmnifluxOmniflux Posts: 442
    renderSerFilename is used when rendering an animation to a series of images instead of to a video file; each frame will increment the number at the end of the filename.
  • Ok, so maybe not script, but plugin... (lol)
    Are there people who does those kind of plugins, or do we have to hope for the dev's to make it?
