Tutorial instruction box shrinkage
gpgailergpgailer Posts: 0
Okay, so this might be an odd problem, but... I'm going through the tutorial walk through for the Sci-Fi Warrior and I make it to'Positioning th Light'. So far so good. I get to the 'Z Translate' slider section and the instruction box shrinks to three lines, hiding the number I need to move the slider too and I have no idea what to do next. Help? Even a little bit?
EDIT: Problem solved, but I had to start the tutorial from the beginning. Kind of annoying.
EDIT2: And it's back in 'Aiming the Lights' only this time restarting the tutorial doesn't help. What the heck is going on here?
Post edited by gpgailer on
  • emmanuel.jacobyemmanuel.jacoby Posts: 2
    edited April 2015
    I get the same problem. I cannot finish the tutorial. I cannot see the values tu set in the parmeters
    Post edited by emmanuel.jacoby on
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,835
    This might be related
    several scripts for DS3 that also work in DS4 since 4.7 have very tiny boxes as the bottom of the window nears some disapperaing.
    pp2 creator being one, I had to guess where save was for creating the Poser prop in DAZ (not wanting a .duf file)
    Is there anything i can do ? like reporting a bug ?
