NGM for Genesis Female question
ShaggeShagge Posts: 74
I've run into a couple of odd issues when using this morph. Mostly it's just and issue with the breasts seeming to sag more than normal. Does anyone have any suggestions.
  • fixmypcmikefixmypcmike Posts: 19,711
    Isn't that what it's supposed to do?
  • ShaggeShagge Posts: 74
    Honestly that's what i've been trying to figure out because a lot of times i've had some people saying they seem to sag more that is normal so i'm figuring i'm not using the tool correctly so advice is welcome.
    Let's put it this way...in this day and age of implants, surgery and all sorts of 'support' devices, I'm not sure what 'normal' sag is...and I'm pretty sure most of the rest of the industrial world isn't, either. But that said...a little goes a long way.
    I just wanted to make sure I was just looking at some of these as i'm messing with the morph going wow its almost to her navel. Thank you all for your help.
    Yeah...that's a little much...but if you can get your hands on old National Geographic magazines (like from the 1920s through the 1960s) you can confirm whether or not that gets close to reality.
    You should be able to control how much but not applying them at full strength.
