Problem with Daz Horse 2 tail
I recently purchased the Daz horse 2 and the hair listed for the tail will not load correctly. It loads a white object, but does not look like a horse tail. Any suggestions?
  • I think this was using a custom 3Delight shader, which will not automatically convert to Iray. You could select the tail areas and apply the Iray Uber Base preset (which is what DS does) then try aplying the xisting maps to build up a reasonable look (all in the Surfaces pane) or you could use an Iray material set for the horse instead.
  • Thanks, I'll give that a try.
  • Same here. And can't locate Iray Uber Base preset. Where is that hiding. :-)
  • GordigGordig Posts: 10,797
    It's in your default resources.
  • Thanks found it and when applying before or after the shader, still get the same results. Been using DaZ for years and never have encountered this before . Tried with 4.15 and 4.16.  Got a bunch of horse drawn vehicles and no way to pull them along. :-)
  • FishtalesFishtales Posts: 6,231
    Load the tail. Select it in the Scene Tab.
    Use the Surface Selection Tool and select ALL the tail, it is in several parts.
    Add the Material.
    Use the Iray Uber Shader to convert to Iray.
    Works fine here.
    All the horse loads white here until the materials are added.
