Zbrush morphs - wrong geometry
All of a sudden when I go Z from DS then export it out and save it then try and use as a morph it does the wrong geometry thing.  Any ideas?
  • RawArtRawArt Posts: 6,228
    Make sure you exported and imported at the same base resolution. Make sure there was nothign attached like eyelashes etc.
    Those are the usual common causes
  • Thank you.
  • marblemarble Posts: 7,500
    From what I remember, GoZ sets the right parameters so that you don't need to worry about base resolution, etc. There was a time when I had access to ZBrush but not after I retired so I use Blender now and I do have to be careful about those settings.
