Bambino range boots and jeans for G8F linked to wrong folder loads grey blocks (Solved)
Hi all,
Either someone was watching Netflix instead of doing their job or simply it did not go thourgh QC/QA at all whatsoever. Either way very disappointing.
https://www.daz3d.com/bambino-range-boots-and-jeans-for-genesis-8-female-s
When I try to load the boots is trying to find the files in a non-existing folder (see attached image)
The files it try to load are actually found in this other folder instead.
...\data\ChungDan\Bambino Range Boots and Jeans\Bambino Range Boots\Morphs\Chungdan\Base
I know I can simply create those folder and move the files there (I guess i could also change the metadata and update to the correct folder, but I'm not at that level yet).
It is so frustrating that something so obvious that wouldn't pass QC/QA can be released just like that.
Nothing against the artist, the full blame and responsibility relies on DAZ.
DAZ should invest more money and time on QC/QA and stop wasting those resources in messing up the product page and crappy things nobody wants.
Have you 'updated' the product recently?
http://docs.daz3d.com/doku.php/public/read_me/index/47729/start
According to file list
http://docs.daz3d.com/doku.php/public/read_me/index/47729/file_list
The correct path is; .../data/chungdan/Route 23/jean/Morphs/Chungdan/...
Thanks again for tackling my whining :)
Yes I have, my mistake was that I have customized folders, but the updated version of the boots was in the default folder used by DIM and not in the customized location where I tried to load the asset from. So using the updated version works.
However, the docs information you are citing is still wrong because I don't have that path you mentioned. There is no folder Route 23 at all. I still have the path I copied.
Thanks again.
Cheers
