We're Not Alone
vonHobovonHobo Posts: 1,715
https://www.daz3d.com/were-not-alone-bundle
Does the flying saucer that comes with this bundle include the effect shown in the promo images?
Or do I need another product to create the light beam effects reaching down from the saucer?
https://www.daz3d.com/extraterrestrial-flying-saucer
1000 x 1300 - 84K
1000 x 1300 - 1005K
  • They may be popstwork, image editing done after rendering, but if not you could probably achieve the second at least with a cone primitive (Create>New Primitive) given rduced opacity and soem emission (in the Editor tab of the Surfaces pane). I'm pretty sure the first one has a spot-light almost directly behind the figures to give the rim effect, the beam might be a cone with a map applied to Cutout Opacity or translucence but it might also be an effect with the foreground figures having been rendered separately to generate a mask that could hide the parts behind them.
  • vonHobovonHobo Posts: 1,715
    Thank you Richard!
    I will try your suggestion. But I also have the Ghost Lights for Iray product
    https://www.daz3d.com/iray-ghost-light-kit-3
    which has a column type spot light and haze effect, so that might work too
  • Yes, probably - or it may be something like one of Jepe's effects (or similar - several people have done effects products using images on a plane or set of planes), on a plane or a cone.
