matter about using "Genesis 2 Female(s) Morphs Bundle"
kyoreonakyoreona Posts: 222
Sorry to trouble you , gentlemen ~
But I have a problem when I use "Genesis 2 Female(s) Morphs Bundle"
I have pressed "CTRLBodybuilder" and "FBMGlutesSize" and so on , but nothing happened , and I can't find any different on parameters and shaping panel.
  • R25SR25S Posts: 595
    edited March 2015
    Most Morphs are found in the Shaping Tab in the Editor Tab
    459 x 664 - 52K
    Post edited by R25S on
  • Richard HaseltineRichard Haseltine Posts: 111,173
    You shouldn't be seeing the CTRL in the name -are you looking at the sliders in the Parameters or Shaping pane, or are you seeing files with those names in the Content library? if the latter it sounds as if you have the files from \Data\DAZ 3D\Genesis 2\Female\Morphs in the wrong place - the Data folder should be in the root (not a sub-folder) of your content directory, and should not show in the content panes at all.
  • kyoreonakyoreona Posts: 222
    thanks for answering , the problem was solved !yes
