Exporting Growing Up for Gen8 Probs
Posted this on the product page and got zero response so thought I'd go broader.
I've had the product bundle for https://www.daz3d.com/growing-up-for-genesis-8-female-s for a few years, but haven't used it for awhile and particularly not with 4.16 of DS.
I generally export via FBX, but don't recall having to Bake anything before.  But even so, Baking to transforms doesn't work in this case.  Not only aren't they baking, but they revert to the adult stage after this first pass. If you try to bake & you accept the defaulted starting Poses category, DS hangs.  Why???
So I do every category, ONE at a TIME, and that generally works.  But in this case, no. And if I don't bake, the same thing.
Not having proper docs on any of this certainly doesn't help, but is there method or recipe I should be looking at for this, such as am I missing a step?
Or could someone explore this a bit more see if something is amiss?
    Have you tried memorizing the figure before baking/exporting?
  • Doc AcmeDoc Acme Posts: 1,153
    Mmm no, but never did before.  Certainly will give that a try.
  • HavosHavos Posts: 5,707
    I always thought bake to transforms was for converting the poses created using Pose Controls into standard bone rotations. What would this do for morphs, as it being asked for in this thread?
    It might be.  Let's look it up in the documentation.  Oh, that right ...
    BTW, I tried both Memorize and Lock and it worked for the export.  I've know idea which tool did the trick. Again if there was documentation, I could look up what the difference is & how & when ypu use those.
