My content keeps getting un installed
Drogo Nazhur
About half of my content is greyed out. Last time that this happened, I went into DIM, uninstalled everything and re installed everything. That took several days.Now it is happening again.
Is there a better way to re-install the missing stuff and why does this keep happening?
How are you installing your content?
The grayed out thumbnails are already telling us, that you are logging in to DS - Do you do that because you install your content solely with DAZ Connect inside DS?
If you are using DAZ Install Manager (DIM), DAZ Central or manual installation, there is no reason to log in to DS and not logging in would save you from problems like this.
I installed with DIM. And I'm not logging in. I just start up the program. Maybe it is doing it automaticly. How do I logout?
Ok, I found it. I logged out but the greyed out stuff is still greyed out.
Set you startup options in DS preferences as in the attachment.
Don't remember the procedure to reimport metadata into the database, but I think someone comes up with it shortly. Reinstallation of all content should not be necessary.
Content DB Maintenance -> Re-Import metadata
thank you
