M4 clothes do not conform to body morphs
Is there something to set so when the body expands the clothes will move with the body. The clothes conform fine for a pose, they are fitted.
  • VicSVicS Posts: 1,273
    Here's the image
    1911 x 1462 - 2M
  • LeanaLeana Posts: 13,617
    Clothes for M4 don't follow all morphs automatically, only the ones for which the clothes provide a matching morph with the right name.
    There might be a morph in the clothes which you need to manually set to match the morph you used.
    There's also a command called "transfer active morphs" you can use to make a clothing item fitted to your figure follow all morphs you used in the figure (basically it add matching morphs in the clothes for all the morphs you used on the figure which don't already have one). From memory it's available in the context menu you get when you right-click on the selected clothing item, and also in the "edit" menu.
    That does work all clothes conformed to the bigger belly, the shoulders however got poke through, if there is no better solution I can fix that with the mesh grabber, thanks Leana!
    Transfer active morphs (found in edit-figure) did work last time I tried, this time it isn't, I thought maybe casue I was using a previous characterso when I loaded up a new M4 but same thing,  the sudden transfer active morphs will not work for me.
