Iray skin for g2f eye color trouble.
IsazformsIsazforms Posts: 210
Hi, I have a little problem. When applied Iray skin materials in genesis and put blue eyes material, in the render , shows black eyes . How I can prevent that from happening ? What setting have to change ?
  • fixmypcmikefixmypcmike Posts: 19,718
    How are you applying the blue eye material? In the Surfaces pane in the upper left when the eye material surface is selected, does it stil show the Iray shader? I'm guessing that the material preset you're using is changing the shader back to a non-Iray shader. Either apply the eye material first, or re-apply the Iray shader by holding down Ctrl/Cmd whilw double-clicking and setting Maps to Ignore so it keeps the blue texture map.
  • IsazformsIsazforms Posts: 210
    I apply all materials first. Then Iray material settings.
    If you go to the Surfaces pane and select the Iris material zone, what shader does it show in the upper left? Is the blue texture map showing to the left of the Diffuse Color?
