How to convert Iray weight % into RGB values?
PA_ThePhilosopherPA_ThePhilosopher Posts: 1,039
Hey all,
I just had a quick question. I was wondering if anyone knew of a quick reference/guide to convert map weight percent to a RGB values.
For example, Translucency weight of 85% corresponds to what shade of grey?
I assume the scale is from 0 to 255 for RGB values (0% weight to 100% weight respectively).
So, based on my example above, 85% of 255 is 216.75. Would this be the equivelent RGB value?
Many thanks,
-P
Post edited by PA_ThePhilosopher on
  • Seven193Seven193 Posts: 1,156
    I hope this isn't a trick question, but I would guess:
    100% white (255,255,255)
    85% white (216.75, 216.75 216.75)
  • felisfelis Posts: 6,502
    Yes, it is a logical guess, but you can't be sure that it is a linear scale.
  • SpaciousSpacious Posts: 481
    edited January 2022
    Translucency weight does not correspond to any color or shade.  It describes how much translucency a surface has.  The color would varry based on what the base color is, among other factors.  Perhaps I'm not correctly understanding your question.
    Post edited by Spacious on
    I think it is a linear scale.
    I tried to make 2 planes, one with translucency weight of 0.85, and the other with translucency weight 1 and an image with 3*217.
    They look fairly identical to me.
    1920 x 1080 - 3M
    Maybe try that experiment with cubes and you'll start to understand what I mean.
    edited January 2022
    I came back because I realized that I misunderstood the question.  You're trying to figure out what grayscale colors to use on translucency weight maps.  Sorry for my earlier answers.  I feel kind of dumb now.  I think you're on the right track.
