a character with no butt
Hi -
Feel like an idiot. I have a character with no butt crack. What dial settings do I use to get a butt crack on this character? Seems like I change everything except that.
Thanks
  • FenixPhoenixFenixPhoenix Posts: 3,249
    Select your character and check the parameters pane (Windows > Tabs/Panes > Parameters), then select "currently use" to see what morphs you may have active.
  • KeithHKeithH Posts: 338
    Here are the currently used sliders. It looks funny with no butt crack.
    427 x 630 - 57K
    422 x 635 - 64K
    428 x 640 - 67K
    425 x 637 - 64K
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,716
    is the Spandex, supposed to look like wearing spandex clothing
    Like WendyLuvzCatz points out, it may be that the spandex morphs smooths out the bodies. So try setting those to 0 to see of it fixes the issue.
  • I strongly suspect the "Vika Hip Spandex" morph is responsible.
    It makes the opening between the thighs a little wider
    Will give it a go and post back the results. Thanks
  • kyoto kidkyoto kid Posts: 42,465
    ...when I saw the title, the first words that came to mind were "and now, for something completely different..."
    YES! - It was the spandex sliders. Thank you so much
