Which type of light for a crisp shadow?
I'm trying to just create a shadow of something, as in, the end render won't show the object but only the shadow.
Seems easy in theory but I can't get any of the lights (point, spot,etc) to actually cast a shadow. Using iRay btw
  • Olo_OrdinaireOlo_Ordinaire Posts: 763
    edited January 2022
    Make sure you have a surface on which to cast the shadow -- a plane for a floor or a wall, etc. -- also, an object between the spotlight and the surface.
    Then, try using a spotlight from the "Create a New Spotlight" button on the menu bar.   To make the shadow sharper, try playing with the "Beam Exponent" settings in the Light parameters pane when the spotlight is selected in the Scene tab.
    Note that you'll need to either render the scene or use the Iray preview to see the results of all this...
    Cheers,
    Olo
    Post edited by Olo_Ordinaire on
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
