envirosphere and Iray
areg5areg5 Posts: 617
Playing around with Iray. I have the country resort, which has a very nice envirosphere that I use for a lot of backdrops. Doesn't seem to work with Iray. Show up as white. I tried to use it in the environment setting, and it looks massively zoomed in and blurry. Works great with 3delight. Is there a fix for this?
  • Richard HaseltineRichard Haseltine Posts: 111,745
    Try applying the Emissive Iray preset to the surface of the dome, and turn off the dome setting (the skydome from the set is an actual item in the scene, not what the Dome settings work on). If the map looks blown up and blurry on the Iray dome it's probably the wrong layout.
