Hair fractured when applied to a figure
This is Kanade Hair with Kanade 8,
When I tried to use it on the figure,
the tails became like this in the attached file.
How to fix it?
I have no idea, thank!
2560 x 1388 - 1M
How to fix it?
I don't see that loading Geensis 8 female, the hair, and then setting the Kanade shape to 100%
Confirmed that the problem was because I set the figure full body shape to Aiko 8 instead of Kanade 8.
Thanks a lot!
Ah, yes - if you apply a shape that doesn't already have a custom morph in the hair and the shape has sharp chnages in scale then steps like thata re likely to happen - morph projection tries to keep the model (the hair) close to the matching areas of the figure it is fitted to, so if there is a big change over a short distance the result will be an abrupt change in the model's shape.
