Map transfer tutorial HELP
Oso3D
The hardest thing about Daz3d is the lack of documentation for ANYTHING. Grr.
Ok, so I've looked at various map transfer tutorials and they are clear as mud.
Can someone walk me through how this works, for, say, trying to get Genesis to Genesis 2 Male?
Looking at the tutorial:
Start map transfer. Ok...
Load UV set. Um. From where?
Once I have stuff transferred (hopefully), how do I get it to work in another figure?
I'm so confused.
http://sickleyield.deviantart.com/journal/Tutorial-The-Map-Transfer-Utility-368686796
Quote:
"Now select one of the materials. It doesn't matter which. Click on the little icon in the upper left of the Surfaces tab; it looks like a small stylized sheet of paper with lines and a little arrow on it. It has many options, including Load UV Set and, just under that, Map Transfer. Click on Map Transfer."
I must be mind clogged by the elections rally in my country these last days but I do not understand your tut SickleYield
But I've only read it once with the comments. I miss a general explanation based on concepts rather than this figure or the other. I am trying to use the tool and the only bitmap (jpg) that transfers is the Normal map. All the others are black. I will keep trying.
Thanks for your question Will, thanks for your tuts SickleYield
