Daz Studio components Download/Install Failed
magog_a4eb71abmagog_a4eb71ab Posts: 769
Successfully Installed:
Default Resources for Daz Studio 4.15+, dForce Starter Essentials, Interactive Lessons for Daz Studio 4.10+, PostgreSQL CMS
However, the rest of the stuff failed to install, most of which is probably due to Daz Studio 4.16 itself failing to install. I also tried redownloading Daz Studio 4.16 since I thought maybe the download went bad, so that's probably why there's an additional error about it already existing. At that point I just stopped and went to the log file in DIM. Here is the log, which curiously is telling me that its running on Windows 8 when this is a Windows 10 Pro OS:
2022-01-10 15:32:00.668 +++++++++++++++ Install Manager 1.4.0.80 starting +++++++++++++++++
2022-01-10 15:32:00.668 OS bits: 64
2022-01-10 15:32:00.668 Platform bits: 64
2022-01-10 15:32:00.668 Qt Version: 4.8.7
2022-01-10 15:32:00.668 Locale: en_US
2022-01-10 15:32:00.668 Running on Windows 8, Build 9200, No Service Pack Installed
2022-01-10 15:32:00.668 Physical Memory:
2022-01-10 15:32:00.668     Total: 95.8 GB (102969479168)
2022-01-10 15:32:00.668     Avail: 91.8 GB (98598248448)
2022-01-10 15:32:00.668 Virtual Memory:
2022-01-10 15:32:00.669     Total: 127.9 TB (140737488224256)
2022-01-10 15:32:00.669     Avail: 127.9 TB (140732961038336)
2022-01-10 15:32:00.669 Current Memory Usage: 4%
2022-01-10 15:32:00.669 Current DateTime:
2022-01-10 15:32:00.669     Loc: Mon Jan 10 15:32:00 2022
2022-01-10 15:32:00.669     UTC: Mon Jan 10 20:32:00 2022
2022-01-10 15:32:00.669 Application Data:
2022-01-10 15:32:00.669     Location = C:/Users/Owner/AppData/Roaming/DAZ 3D/InstallManager
2022-01-10 15:32:00.669     Disk Total: 1.8 TB (1999745576960)
2022-01-10 15:32:00.669     Disk Avail: 1.6 TB (1842447216640)
2022-01-10 15:32:00.670 Reading dzInstall.ini
2022-01-10 15:32:00.670 Cannot locate dzInstall.ini
2022-01-10 15:32:00.671 Starting CMS...
2022-01-10 15:32:00.671 Error connecting to CMS. Cannot be started by client.
2022-01-10 15:32:56.357 Current Account: Account
2022-01-10 15:32:56.358 Current Download Path:
2022-01-10 15:32:56.358     Location = C:/Users/Public/Documents/DAZ 3D/InstallManager/Downloads
2022-01-10 15:32:56.358     Disk Total: 1.8 TB (1999745576960)
2022-01-10 15:32:56.358     Disk Avail: 1.6 TB (1842446680064)
2022-01-10 15:32:56.358 Current Content Install Path:
2022-01-10 15:32:56.358     Location = C:/Users/Public/Documents/My DAZ 3D Library
2022-01-10 15:32:56.359 Current 64-bit Software Install Path:
2022-01-10 15:32:56.359     Location = C:/Program Files
2022-01-10 15:32:56.359     Disk Total: 1.8 TB (1999745576960)
2022-01-10 15:32:56.359     Disk Avail: 1.6 TB (1842446680064)
2022-01-10 15:32:56.359 Current 32-bit Software Install Path:
2022-01-10 15:32:56.359     Location = C:/Program Files (x86)
2022-01-10 15:32:57.332 Remote Products: 341
2022-01-10 15:32:57.333 Remote Packages: 416
2022-01-10 15:34:21.013     Json Parser (1,1): Syntax error - expected '{' or '['
2022-01-10 15:34:30.944 Installing: 18869-2 : PostgreSQL CMS (Win 64-bit)
2022-01-10 15:34:39.334 WARNING: QProcess: Destroyed while process is still running.
2022-01-10 15:35:04.406 Starting CMS...
2022-01-10 15:35:10.990 Connected to CMS: PostgreSQL 9.3.4, compiled by Visual C++ build 1600, 64-bit
2022-01-10 15:35:11.078 Install Successful: PostgreSQL CMS (Win 64-bit)
2022-01-10 15:35:11.078 Installing: 13176-45 : Interactive Lessons for DAZ Studio 4.10+
2022-01-10 15:35:11.086 WARNING: Could not set permissions on file: C:/Users/Public/Documents/My DAZ 3D Library/InstallManagerFileRegister.json
2022-01-10 15:35:11.438 Install Successful: Interactive Lessons for DAZ Studio 4.10+
2022-01-10 15:35:11.438 Installing: 13176-42 : Default Resources for DAZ Studio 4.15+
2022-01-10 15:35:15.807 Install Successful: Default Resources for DAZ Studio 4.15+
2022-01-10 15:35:15.807 Installing: 47939-1 : dForce Starter Essentials
2022-01-10 15:35:18.218 Install Successful: dForce Starter Essentials
2022-01-10 15:35:18.219 Install Queue Finished: 0 min 55.8 sec
2022-01-10 15:35:26.726 Installing: 21630-2 : Genesis 3 Starter Essentials Male
2022-01-10 15:35:26.726 Requirement Failed:  : moving on
2022-01-10 15:35:26.731 Install Queue Finished: 0 min 0.0 sec
2022-01-10 15:37:15.109 Installing: 42071-2 : Genesis 8 Male Starter Essentials
2022-01-10 15:37:15.109 Requirement Failed:  : moving on
2022-01-10 15:37:15.115 Install Queue Finished: 0 min 0.0 sec
2022-01-10 15:37:16.225 Installing: 13176-2 : DAZ Studio 4.16 (Win 64-bit)
2022-01-10 15:37:16.226 Requirement Failed:  : moving on
2022-01-10 15:37:16.230 Install Queue Finished: 0 min 0.0 sec
2022-01-10 15:37:19.684 Installing: 42071-1 : Genesis 8 Female Starter Essentials
2022-01-10 15:37:19.684 Requirement Failed:  : moving on
2022-01-10 15:37:19.688 Install Queue Finished: 0 min 0.0 sec
2022-01-10 15:37:43.296 Installing: 18009-1 : DM's Memorial DS
2022-01-10 15:37:43.297 Requirement Failed:  : moving on
2022-01-10 15:37:43.301 Install Queue Finished: 0 min 0.0 sec
2022-01-10 15:38:00.138 Installing: 21630-1 : Genesis 3 Starter Essentials Female
2022-01-10 15:38:00.138 Requirement Failed:  : moving on
2022-01-10 15:38:00.147 Install Queue Finished: 0 min 0.0 sec
2022-01-10 15:38:13.775 Installing: 22773-1 : Dark Fantasy Weapons for Genesis 3 and 8 Female(s)
2022-01-10 15:38:13.775 Requirement Failed:  : moving on
2022-01-10 15:38:13.779 Install Queue Finished: 0 min 0.0 sec
2022-01-10 15:38:19.000 Installing: 13305-1 : Secret Garden Shaded Haven
2022-01-10 15:38:19.000 Requirement Failed:  : moving on
2022-01-10 15:38:19.005 Install Queue Finished: 0 min 0.0 sec
2022-01-10 15:39:00.002 Installing: 41753-1 : Rocker Outfit for Genesis 3 Female(s) and Genesis 8 Female(s)
2022-01-10 15:39:00.002 Requirement Failed:  : moving on
2022-01-10 15:39:00.007 Install Queue Finished: 0 min 0.0 sec
2022-01-10 15:39:09.597 Installing: 21848-1 : DAZ Studio Iray HDR Outdoor Environments
2022-01-10 15:39:09.597 Requirement Failed:  : moving on
2022-01-10 15:39:09.602 Install Queue Finished: 0 min 0.0 sec
2022-01-10 15:39:14.373 WARNING: Download Error: IM00021630-02_Genesis3StarterEssentialsMale.zip : Error - 403 : Forbidden
2022-01-10 15:39:14.373 WARNING: Network Error:  : Operation canceled
2022-01-10 15:39:14.373 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2022-01-10 15:39:14.892 WARNING: Download Already Exists: 42071-2 : Genesis 8 Male Starter Essentials : C:/Users/Public/Documents/DAZ 3D/InstallManager/Downloads/IM00042071-02_Genesis8MaleStarterEssentials.zip
2022-01-10 15:39:17.854 Installing: 4222-1 : Hexagon 2.5 (Win)
2022-01-10 15:39:18.205 Install Failed: Hexagon 2.5 (Win)
2022-01-10 15:39:18.207 Installing: 4222-21 : Hexagon 2.5 Content
2022-01-10 15:39:18.219 Application Not Found: Hexagon 2.5
2022-01-10 15:39:18.219 Requirement Failed: IM00004222-21_Hexagon25Content.zip : moving on
2022-01-10 15:39:18.220 Install Queue Finished: 0 min 4.1 sec
2022-01-10 15:39:18.448 WARNING: Download Error: IM00013176-02_DAZStudio416Win64bit.zip : Error - 403 : Forbidden
2022-01-10 15:39:18.448 WARNING: Network Error:  : Operation canceled
2022-01-10 15:39:19.011 WARNING: Download Already Exists: 42071-1 : Genesis 8 Female Starter Essentials : C:/Users/Public/Documents/DAZ 3D/InstallManager/Downloads/IM00042071-01_Genesis8FemaleStarterEssentials.zip
2022-01-10 15:39:19.434 Installing: 46691-1 : Shadow Thief Outfit for Genesis 8 Female(s)
2022-01-10 15:39:19.434 Requirement Failed:  : moving on
2022-01-10 15:39:19.439 Install Queue Finished: 0 min 0.0 sec
2022-01-10 15:39:19.877 WARNING: Download Already Exists: 18009-1 : DM's Memorial DS : C:/Users/Public/Documents/DAZ 3D/InstallManager/Downloads/IM00018009-01_DMsMemorialDS.zip
2022-01-10 15:39:36.373 WARNING: Download Error: IM00021630-01_Genesis3StarterEssentialsFemale.zip : Error - 403 : Forbidden
2022-01-10 15:39:36.373 WARNING: Network Error:  : Operation canceled
2022-01-10 15:39:36.374 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2022-01-10 15:39:36.651 WARNING: Download Already Exists: 22773-1 : Dark Fantasy Weapons for Genesis 3 and 8 Female(s) : C:/Users/Public/Documents/DAZ 3D/InstallManager/Downloads/IM00022773-01_DarkFantasyWeaponsforGenesis3and8Females.zip
2022-01-10 15:39:55.332 WARNING: Download Already Exists: 13305-1 : Secret Garden Shaded Haven : C:/Users/Public/Documents/DAZ 3D/InstallManager/Downloads/IM00013305-01_SecretGardenShadedHaven.zip
2022-01-10 15:40:53.979 Installing: 46693-1 : Shadow Thief Outfit Textures
2022-01-10 15:40:53.979 Requirement Failed:  : moving on
2022-01-10 15:40:53.989 Install Queue Finished: 0 min 0.0 sec
2022-01-10 15:40:54.302 WARNING: Download Already Exists: 41753-1 : Rocker Outfit for Genesis 3 Female(s) and Genesis 8 Female(s) : C:/Users/Public/Documents/DAZ 3D/InstallManager/Downloads/IM00041753-01_RockerOutfitforGenesis3FemalesandGenesis8Females.zip
2022-01-10 15:41:18.467 WARNING: Download Error: IM00021848-01_DAZStudioIrayHDROutdoorEnvironments.zip : Error - 403 : Forbidden
2022-01-10 15:41:18.468 WARNING: Network Error:  : Operation canceled
2022-01-10 15:41:18.468 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2022-01-10 15:41:18.917 WARNING: Download Error: IM00046691-01_ShadowThiefOutfitforGenesis8Females.zip : Error - 403 : Forbidden
2022-01-10 15:41:18.917 WARNING: Network Error:  : Operation canceled
2022-01-10 15:41:18.917 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2022-01-10 15:41:19.334 WARNING: Download Error: IM00046693-01_ShadowThiefOutfitTextures.zip : Error - 403 : Forbidden
2022-01-10 15:41:19.334 WARNING: Network Error:  : Operation canceled
2022-01-10 15:41:19.334 WARNING: QNetworkReplyImplPrivate::error: Internal problem, this method must only be called once.
2022-01-10 15:41:37.546 Install Queue Finished: 0 min 0.0 sec
2022-01-10 15:43:54.516 WARNING: Download Already Exists: 13176-2 : DAZ Studio 4.16 (Win 64-bit) : C:/Users/Public/Documents/DAZ 3D/InstallManager/Downloads/IM00013176-02_DAZStudio416Win64bit.zip
It looks like Malwarebytes Anti-Malware is installed on this system so it might have something to do with it, but I'm not sure.
Post edited by magog_a4eb71ab on
  • MalwareBytes doesn't cause issues for me, and I had it (an older vrsion, obviously) installed before installing DS on this system.
    Check to see if you have the zips for the applications in the Downloads folder already, if you do dlete them and try again. Failing that, try manually downloading from the Product Library in your account pages and place the zips in the DIM downloads folder - C:/Users/Public/Documents/DAZ 3D/InstallManager/Downloads/ according to your log, then start/refresh DIM and try installing from the Ready to Install tab.
  • magog_a4eb71abmagog_a4eb71ab Posts: 769
    edited January 2022
    Thanks Rich. I'm not sure if I want to go deleting stuff just yet. Yes, the zip files are in Users/Public/Public Documents/Daz 3D/InstallManager/Downloads . I jumped over to my Win7 laptop where I already have Daz installed and checked the security settings on the "Public" folder and everything is checked in the "Allow" column except for Special Permission. However, on this Win10 system, that folder has everything unchecked in the Allow column except for Special Permission which might be the problem. I'm not sure how to go about changing that if that would be the cause of the problem. I'll edit my previous post and highlight the errors.
    The other errors relating to the files already existing is because I tried to install them again figuring it something might have went wrong with the connection.
  • Update:
    I went into the Security tab a bit more and checked the Special Permission constraints and based on what I saw, I don't think that was the issue since I'm logged into windows with an account that has full control. HOWEVER, when I tried to install the files again after messing about for about an hour, it worked! I believe what happened is the download/install order messed things up due to differing download completion times between the different packages(just a guess) where certain things needed to be installed first. Anyway, I'm going to try firing up Daz Studio and see what happens now that I have it installed and the essentials for G3-G8.
  • Ok, no problems making a new Base directory in Daz Studios for both Smart Content & Renderosity content on my storage drive and then pointing DIM to the new Smart Content directory. I installed Victoria 8 to this new location and it shows up in the Smart Content tab in DS, so everything seems to be working so far in regards to installation & adding the new locations.
    Loaded V8 and one of the RuinsB environment background, did a spot render and it rendered in like 3 seconds on the A6000. By the way, whatever happened to the Environment tab?? I added it to the pane where we have the Smart Content, Content Library, etc., tabs and its completely blank. I also noticed it doesn't load any default HDRI like it did in 4.10, so you can't access thing like Environment Intensity, Dome Rotation, etc.
  • cgidesigncgidesign Posts: 442
    edited January 2022
    In newer DS versions the tonemapper, environment, filament nodes might not load by default.
    In that case do it by hand:
    472 x 818 - 152K
    Post edited by cgidesign on
    They will also be created if you render or enable a PBR Drawstyle for the Viewport.
    Am I understanding correctly that the Environment tab that use to be on the left is no longer used? I can still create the Environment tab where I was use to finding it in 4.10, but its completely blank. It seems that this was replaced by nodes and is instead found on the right side under the Parameters tab after selecting the respective node in the Scene box.
  • MelanieLMelanieL Posts: 7,867
    Not exactly - once the nodes are created, they automatically populate the Environment tab of Render Settings, which you can then use to adjust the settings if you prefer that to the parameters tab.
  • The environment pane does a different job - it is for setting  ab abckground image/colour, and doesn't depend onm the singleton settings node.
    edited January 2022
    Ah, I missunderstood the initial question.
    The environment tab for backdrops is empty by default:
    There was a thread some time ago about light and the difference between Environment and "the other" Environment (DAZ Studio has to of them which do different things):
    https://www.daz3d.com/forums/discussion/comment/6565331/#Comment_656533
    1300 x 467 - 94K
  • Hi, I'm new to Daz. I tried to install it on a new computer, but my models don't load properly.
    my video card is an asus tuf gaming 3090 but it doesn't load the models well and my old gtx 1050 video card loads them well.
    does anyone know why?
    1920 x 1080 - 661K
