How to find out wich Character is used?
R25SR25S Posts: 595
Is their a way to find out what Character and Skin is used in a Scene?
Of course I have the Scene and can copy the figure and merge them in the new Scene but if I want to know wich one it was how can you find out?
Exempe; can I find out Figure used is Maia with Skin used from Ginger?
  • kaotkblisskaotkbliss Posts: 2,918
    For skins, if you click on the model and go to surfaces, select one of the model's surfaces and check the diffuse setting, it will tell you there what file is being used.
    As for actual product names for objects in a scene, Sometimes I wish there was something that would tell you because often times the name in the scene tab doesn't match the file name and sometimes I forget where I got something from.
    *Side note*
    Woohoo! my 500th post lol.
  • Richard HaseltineRichard Haseltine Posts: 111,363
    In DS you can click the Currently used group on the left of the Parameters or Shaping pane and see if there's a single, named, morph for the character. Or you can go to the Surfaces pane, select one of the skin surfaces, and hover over one of the texture thumbnails (diffuse colour for example) to look at the path on the pop-up image. If neither of those helps then probably not.
  • R25SR25S Posts: 595
    Unfortunately Skin Diffuse Tab shows nothing.
    Currently used shows a few Morphs that where used but not the Base Figure used.
    I should make some notes of used Figures, Morphs, Skin and Hair next time.
    Thank you, for the quick answers.
    351 x 764 - 44K
  • prixatprixat Posts: 1,627
    Look in the Log file you may be able to tell from the files and morphs listed there.
    This is the last few lines of the log straight after loading a V6 with the Belle texture with Toulouse Hair:
    Brilliant Idea; that it.
    Thank you.
    On a side note, if you look at your diffuse box next to the slider, you'll notice that there is no down arrow. That usually means that more than 1 surface is being looked at (which is why you are not seeing an image or the down arrow) I believe the (13) is telling you that there are 13 areas selected.
    Go to the surfaces section right below skins that you have selected and you can see each part of the body (head, arms, hands, etc.) clicking on 1 of these and checking the diffuse will show you the filename and a thumbnail image of the texture being used.
    Ah; OK; my fault. I thought you mean Surface Tab / Surfaces / (Figure) / Skin / Diffuse.
    Under Surfaces Tab / Surfaces / (Figure) / Surfaces / (Body Part) / Diffuse there are the used Skin; that works, too.
    Thank you, for the clearance.
    I wasn't very specific before, just giving the general area to look in, so that's my fault.
