Morphs help
LordScorpion13LordScorpion13 Posts: 25
Okay.. I made this character.. 3 custom morphs (ears, body, head) and she looks great! Saved them in order to put a figure preset together..
C:\Daz3d\data\Daz 3D\Genesis 2\Female\Morphs\Scorpie\Belladonna for G2F
This is the folder with the morphs btw
I botched somewhere.. because EVERY G2F model I load gets the same morphs... I mean I can dial them back to zero.. but I'd like to fix whatever I did...
Help plz!
    Open the file with a text editor (you may need to decompress it first), find the line ... "value" : 1 ... and change the 1 to 0, save file.
  • Richard HaseltineRichard Haseltine Posts: 112,074
    Or in DS click the gear on the parameter's slider, select Parameter Settings, set the default and current values to 0, and use File>Save as>Support Assets>Save Modified Assets (make sure that only the things you are resetting are listed).
  • LordScorpion13LordScorpion13 Posts: 25
    That did the trick! thanks a ton!
