DS 4.16.1.21 log - memory info missing ?
cgidesign
Older DS versions wrote information about geometry, texture etc. vram usage into the log. I don't find that in the current DS 4.16.1.21 beta log. Is it gone?
Haven't updated yet, but even with the older versions, the information is written only when geometry+textures do fit the available VRAM on the GPU
I did a quick test with one figure only, nothing else.
... - IRAY:RENDER :: 1.3 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 2070 with Max-Q Design): Processing scene...
... - IRAY:RENDER :: 1.2 IRAY rend info : Importing lights for motion time 0
... - IRAY:RENDER :: 1.2 IRAY rend info : Initializing light hierarchy.
... - IRAY:RENDER :: 1.2 IRAY rend info : Light hierarchy initialization took 0.002 s
... - IRAY:RENDER :: 1.3 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 2070 with Max-Q Design): Scene processed in 1.214s
.. - IRAY:RENDER :: 1.3 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 2070 with Max-Q Design): Allocated 12.126 MiB for frame buffer
... - IRAY:RENDER :: 1.3 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 2070 with Max-Q Design): Allocated 1.906 GiB of work space (2048k active samples in 0.007s)
The blue lines seem to be the only info about vram usage. Is there a way to get the full information back?
Without it, it is difficult to analyze / optimize a scene.
Looks like all the lines with [VERBOSE] are missing
2022-01-09 23:54:46.247 Iray [INFO] - IRAY:RENDER :: 1.4 IRAY rend progr: CUDA device 0 (GeForce RTX 2070 SUPER): Processing scene...
2022-01-09 23:54:46.437 Iray [VERBOSE] - IRAY:RENDER :: 1.3 IRAY rend stat : Geometry memory consumption: 548.005 MiB (device 0), 0.000 B (host)
2022-01-09 23:55:13.455 Iray [VERBOSE] - IRAY:RENDER :: 1.3 IRAY rend stat : Texture memory consumption: 1.803 GiB for 147 bitmaps (device 0)
2022-01-09 23:55:13.456 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : Importing lights for motion time 0
2022-01-09 23:55:13.456 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : Initializing light hierarchy.
2022-01-09 23:55:13.824 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : Light hierarchy initialization took 0.368s
2022-01-09 23:55:13.827 Iray [VERBOSE] - IRAY:RENDER :: 1.3 IRAY rend stat : Lights memory consumption: 4.932 MiB (device 0)
2022-01-09 23:55:13.832 Iray [VERBOSE] - IRAY:RENDER :: 1.3 IRAY rend stat : Material measurement memory consumption: 0.000 B (GPU)
2022-01-09 23:55:13.833 Iray [VERBOSE] - IRAY:RENDER :: 1.3 IRAY rend stat : Materials memory consumption: 756.141 KiB (GPU)
2022-01-09 23:55:13.865 Iray [INFO] - IRAY:RENDER :: 1.4 IRAY rend info : CUDA device 0 (GeForce RTX 2070 SUPER): Scene processed in 27.619s
2022-01-09 23:55:13.870 Iray [INFO] - IRAY:RENDER :: 1.4 IRAY rend info : CUDA device 0 (GeForce RTX 2070 SUPER): Allocated 50.091 MiB for frame buffer
2022-01-09 23:55:13.991 Iray [INFO] - IRAY:RENDER :: 1.4 IRAY rend info : CUDA device 0 (GeForce RTX 2070 SUPER): Allocated 1.750 GiB of work space (2048k active samples in 0.121s)
Interesting, is there a way to change the verbose level in DS?
