Can not "Nipple Off"!!!
Leo ChenLeo Chen Posts: 697
Some Genesis 2 characters' nipples can not be turn off!!!
How come?
For example, Yumi for Mei lin 6.
  • XoechZXoechZ Posts: 1,102
    Hm, because nipples are a natural part of every human body and therefore have to be there. LOL :-)
    Now serious.
    What do you mean? The texture? Some vendors include 2 versions of textures, one with nipples and one without. Other vendors do not and there is only one texture available.
    Or do you mean the body itself? Then you can most of the times get rid of the nipples in the shaping tab within the chest section. Look for all nipple related entries and dial them down to zero.
  • Steven-VSteven-V Posts: 727
    He's right. Some of them do not have the shaping tab, and you simply cannot turn the physical structure of the nipple off. Others HAVE the shaping tab, but even with it turned to zero, there is still "nipple bump." Most of the time I want it turned off. My characters wear clothing, not bedroom wear, and most women don't have nipples showing through things like wool sweaters.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,491
    You could hide the pectorals and maybe dial it out in the clothing.
    Maybe we need a nipple poke away.
    edited March 2015
    In this case you can try a little trick. Go to the "Nipple" setting (for example) in the shaping tab and change the parameter settings by clicking on the little gear next to the slider. In the window that opens you see a min value (usually 0) and a max value (usually 1). Now change the min value to a negative value like -1 or -2. Click ok and now you can dial the value to negative. This may look a bit strange on a nude body, but helps to cure the nipple bump under clothes.
    Maybe you have to do the same for other values like areola perk. This depends on the given shape.
    Post edited by XoechZ on
  • wsterdanwsterdan Posts: 3,568
    Maybe you have to do the same for other values like areola perk. This depends on the given shape.Sometimest it works, sometimes it doesn't.
    I have the same trouble with navels. Some vendors add a navel morph so that people with just the basic Genesis/GM2/GF3 models without morph packs can have navels but don't supply a navel-off morph, and even dialling-out morphs using extended limits still show slight navels, even through cloths.
    Vendors, if you're going to be kind enough to add a navel or nipple morph, please allow us to dial 'em off if we need to.
    Thanks.
    -- Walt Sterdan
  • Leo ChenLeo Chen Posts: 697
    Thank you,wendy♥catz.
    You are right, we do need "nipple poke away"!
    But the product does come with a "nipple off" tab.
    How come it does not working?
    Now serious.
    Thank you, XoechZ.
    I mean "body itself"...
    Thank you, steven.viscido.
    The product comes with "nipple off" tab.
    Most of time, I want nipple off too.
    Why DAZ Studio does not have "nipple off" function?
    Thanks.
    -- Walt Sterdan
    Thank you, wsterdan.
    I have bought a lot of 3D products that I know what you feel......
    Maybe, next DAZ Studio will come with "nipple off" and "xxx off"...
    Studio doesn't need a 'nipples off' function as the DAZ base models don't have the nipples or navel on to begin with. The problems is some vendors' custom character morphs have the nipples, navel and sometimes even a vaginal crease sculpted into the character morph. DAZ quality assurance should reject such character morphs.
    Thanks, that's a perfect example of how it should be done.
    -- Walt Sterdan
    -- Walt Sterdan
    But that tab does not work as expected.
    PS:
    EmmaAndJordi's products work.
    Thank you, jestmart.
