How to move a section of the body in DAZ 4.7
Bunyip02Bunyip02 Posts: 9,345
Hello
With my morphs I often translate a section of the body for a better fit, eg eyes might be sticking out after the morph so I translate them back into the head to achieve the required look I was after before I render.
This was easy to do in 4.6.
How do you do it in 4.7, as all I get are surfaces for selection, if I choose the eye surfaces it moves the whole figure ?
Must be an easy way of doing the translation.
Also can the DAZ 4.7 selection be adjusted so we can pick a figure instead of surfaces, as the surfaces option really grates on me as to how I use DAZ.
Very close to reinstalling 4.6.
Many thanks in advance for any help, Bunyip
1950 x 674 - 736K
Post edited by Bunyip02 on
  • srieschsriesch Posts: 4,243
    You have the surface selection tool active, and thus are working with surfaces. Click on the Universal Tool, then you can select nodes instead.
    476 x 146 - 42K
    Looks like you are using one of the 'basic' layouts...Hollywood Bvld. Try switching to City Limits...it has more advanced toolbars.
  • Bunyip02Bunyip02 Posts: 9,345
    Many thank-you's, now back to were I was.
    Don't ask me how it ended up on the Surface Selection Tool, was not using it before I switched from 4.6 to 4.7
    Regards, Bunyip
    More layouts to play with, that could be dangerous for someone like me !!!!!!!
    Many thanks for the advice will need to take a sticky-beak at them.
    Regards, Bunyip
