Unable to Render Error.
Greeting,
I've been Daz3d for a few weeks and this is what I'm being greeted with currently when hitting the Render Icon.  "Unable to Render. No Renderer Available".
Not sure what would've/could've changed.
Any input on a place to start, please?
«1
  • What operating system are you using? What hardware? What driver version? Have you disabled one of the render engines in Help>About Installed Plug-ins? Which render engine is set to be used - Edit or Advanced tabs of Render Settings?
  • cmskcmsk Posts: 42
    edited January 2022
    Hey Richard,
    I'm on a Mac Mini M1 running MacOS Monterey 12.0.1.  Haven't touched the Plug-ins, but on checking there, everything is checked and Green.  Not sure about the driver version.
    Chris
    Post edited by cmsk on
  • What version of Daz Studio is this? Help>About Daz Studio.
    4.16.0.3
  • TotteTotte Posts: 15,316
    edited January 2022
    Do you have CPU checked in Vidia advanced render settings?
    Post edited by Totte on
  • MasterstrokeMasterstroke Posts: 2,525
    cmsk said:
    Greeting,
    Have been into the same problem years ago.
    Where is your content directory installed? It is importent to not have it installed in your DS program folder, like many other apps have it.
    It might go well for some time, but at one point, you'll run into problems, like yours now.
    So to make it clear, don't install "My Library" into the same folder as the "DAZStudio. exe".
    Use the "DAZ Studio 4" folder for your programm files and a seperate "Studio" folder for your assets.
    This is important.
    It was unchecked.  I tried checking it off in both places -- Interactive and Photorealistic ... same result.
    Masterstroke said:
    cmsk said:
    Greeting,
    This is important.
    I have all of my content on an external drive.
    can you post the logfile here?
    You find it under Help -> Troubleshooting -> View log file.
    Go to the bottom of the logifle, the look backwards until you see
    +++++++++++++++ DAZ Studio 4.16.x.x starting +++++++++++++++++
    And take everything from there.
    edited January 2022
    Will do it later today... thank you.
    Added below:
    2022-01-11 19:21:19.273 +++++++++++++++ DAZ Studio 4.16.0.3 starting +++++++++++++++++
    2022-01-11 19:21:19.273 Performing cleanup...
    2022-01-11 19:21:19.283 Release Cycle: General Release
    2022-01-11 19:21:19.283 Platform bits: 64
    2022-01-11 19:21:19.283 Qt Version: 4.8.7
    2022-01-11 19:21:19.284 OpenSubdiv Version: 3.0.0
    2022-01-11 19:21:19.308 Running on Macintosh OS 12.0 Monterey
    2022-01-11 19:21:19.308 Current DateTime:
    2022-01-11 19:21:19.312     Loc: Tue Jan 11 19:21:19 2022
    2022-01-11 19:21:19.312     UTC: Wed Jan 12 00:21:19 2022
    2022-01-11 19:21:19.313 Temp Data:
    2022-01-11 19:21:19.313     Location = /Users/Chris/Library/Application Support/DAZ 3D/Studio4/temp
    2022-01-11 19:21:19.313     Disk Total: 460.4 GB (494384795648)
    2022-01-11 19:21:19.313     Disk Avail: 139.4 GB (149706625024)
    2022-01-11 19:21:19.313 Locale: en_US
    2022-01-11 19:21:19.313     No translator found.
    2022-01-11 19:21:19.326 Creating Plugin Manager...
    2022-01-11 19:21:19.335 Reading style definition /Users/Chris/Daz 3D/Applications/DAZ 3D/DAZStudio4 64-bit/resources/style/Darkside.style
    2022-01-11 19:21:19.746 Creating Import Manager...
    2022-01-11 19:21:19.746 Creating Export Manager...
    2022-01-11 19:21:19.747 Creating File IO Preset Manager...
    2022-01-11 19:21:19.756 Creating Save Filter Manager...
    2022-01-11 19:21:19.757 Creating Asset IO Manager...
    2022-01-11 19:21:19.757 DSON Cache:
    2022-01-11 19:21:19.757     Location = /Users/Chris/Library/Application Support/DAZ 3D/dson/cache
    2022-01-11 19:21:19.757     Disk Total: 460.4 GB (494384795648)
    2022-01-11 19:21:19.757     Disk Avail: 139.4 GB (149706625024)
    2022-01-11 19:21:19.758 Creating Image Manager...
    2022-01-11 19:21:19.758 Creating Help Manager...
    2022-01-11 19:21:19.758 Reading help index
    2022-01-11 19:21:19.759 Reading help file /Users/Chris/Daz 3D/Applications/DAZ 3D/DAZStudio4 64-bit/docs/DAZ Studio/DAZStudioHelp.dsx
    2022-01-11 19:21:19.761 Reading help file /Users/Chris/Daz 3D/Applications/DAZ 3D/DAZStudio4 64-bit/docs/DAZ Studio/inlineHelp/_.dsx
    2022-01-11 19:21:19.778 Reading help file /Users/Chris/Daz 3D/Applications/DAZ 3D/DAZStudio4 64-bit/docs/DAZ Studio/inlineHelp/About Hardware.dsx
    2022-01-11 19:21:19.779 Reading help file /Users/Chris/Daz 3D/Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/StrandBasedHairEditor/StrandBasedHairEditor.dsx
    2022-01-11 19:21:19.782 Reading help file /Users/Chris/Daz 3D/Applications/DAZ 3D/DAZStudio4 64-bit/docs/Plugins/Timeline/Timeline.dsx
    2022-01-11 19:21:19.783 Reading help file /Users/Chris/Daz 3D/Applications/DAZ 3D/DAZStudio4 64-bit/docs/bookmarks.dsx
    2022-01-11 19:21:19.784 Creating Multimedia Manager...
    2022-01-11 19:21:19.784 Creating Content Manager...
    2022-01-11 19:21:19.816 Scanning Import folders...
    2022-01-11 19:21:19.816 Scanning Content folders...
    2022-01-11 19:21:19.852 Creating Render Manager...
    2022-01-11 19:21:19.875 Creating Texture Converter Manager...
    2022-01-11 19:21:19.876 Creating Texture Baker Manager...
    2022-01-11 19:21:19.878 Creating Device Manager...
    2022-01-11 19:21:19.878 Creating CallBack Manager...
    2022-01-11 19:21:20.074 Using GLEW 1.9.0
    2022-01-11 19:21:20.075 Supported OpenGL extensions:
    2022-01-11 19:21:20.075     GL_ARB_color_buffer_float
    2022-01-11 19:21:20.075     GL_ARB_depth_buffer_float
    2022-01-11 19:21:20.075     GL_ARB_depth_clamp
    2022-01-11 19:21:20.075     GL_ARB_depth_texture
    2022-01-11 19:21:20.075     GL_ARB_draw_buffers
    2022-01-11 19:21:20.075     GL_ARB_draw_elements_base_vertex
    2022-01-11 19:21:20.075     GL_ARB_draw_instanced
    2022-01-11 19:21:20.075     GL_ARB_fragment_program
    2022-01-11 19:21:20.075     GL_ARB_fragment_program_shadow
    2022-01-11 19:21:20.075     GL_ARB_fragment_shader
    2022-01-11 19:21:20.075     GL_ARB_framebuffer_object
    2022-01-11 19:21:20.075     GL_ARB_framebuffer_sRGB
    2022-01-11 19:21:20.075     GL_ARB_half_float_pixel
    2022-01-11 19:21:20.075     GL_ARB_half_float_vertex
    2022-01-11 19:21:20.075     GL_ARB_imaging
    2022-01-11 19:21:20.075     GL_ARB_instanced_arrays
    2022-01-11 19:21:20.076     GL_ARB_multisample
    2022-01-11 19:21:20.076     GL_ARB_multitexture
    2022-01-11 19:21:20.076     GL_ARB_occlusion_query
    2022-01-11 19:21:20.076     GL_ARB_pixel_buffer_object
    2022-01-11 19:21:20.076     GL_ARB_point_parameters
    2022-01-11 19:21:20.076     GL_ARB_point_sprite
    2022-01-11 19:21:20.076     GL_ARB_provoking_vertex
    2022-01-11 19:21:20.076     GL_ARB_seamless_cube_map
    2022-01-11 19:21:20.076     GL_ARB_shader_objects
    2022-01-11 19:21:20.076     GL_ARB_shader_texture_lod
    2022-01-11 19:21:20.076     GL_ARB_shading_language_100
    2022-01-11 19:21:20.076     GL_ARB_shadow
    2022-01-11 19:21:20.076     GL_ARB_shadow_ambient
    2022-01-11 19:21:20.076     GL_ARB_sync
    2022-01-11 19:21:20.076     GL_ARB_texture_border_clamp
    2022-01-11 19:21:20.076     GL_ARB_texture_compression
    2022-01-11 19:21:20.076     GL_ARB_texture_compression_rgtc
    2022-01-11 19:21:20.076     GL_ARB_texture_cube_map
    2022-01-11 19:21:20.076     GL_ARB_texture_env_add
    2022-01-11 19:21:20.076     GL_ARB_texture_env_combine
    2022-01-11 19:21:20.076     GL_ARB_texture_env_crossbar
    2022-01-11 19:21:20.076     GL_ARB_texture_env_dot3
    2022-01-11 19:21:20.076     GL_ARB_texture_float
    2022-01-11 19:21:20.076     GL_ARB_texture_mirrored_repeat
    2022-01-11 19:21:20.076     GL_ARB_texture_non_power_of_two
    2022-01-11 19:21:20.076     GL_ARB_texture_rectangle
    2022-01-11 19:21:20.076     GL_ARB_texture_rg
    2022-01-11 19:21:20.076     GL_ARB_transpose_matrix
    2022-01-11 19:21:20.076     GL_ARB_vertex_array_bgra
    2022-01-11 19:21:20.076     GL_ARB_vertex_blend
    2022-01-11 19:21:20.076     GL_ARB_vertex_buffer_object
    2022-01-11 19:21:20.076     GL_ARB_vertex_program
    2022-01-11 19:21:20.076     GL_ARB_vertex_shader
    2022-01-11 19:21:20.076     GL_ARB_window_pos
    2022-01-11 19:21:20.076     GL_EXT_abgr
    2022-01-11 19:21:20.076     GL_EXT_bgra
    2022-01-11 19:21:20.076     GL_EXT_bindable_uniform
    2022-01-11 19:21:20.076     GL_EXT_blend_color
    2022-01-11 19:21:20.076     GL_EXT_blend_equation_separate
    2022-01-11 19:21:20.077     GL_EXT_blend_func_separate
    2022-01-11 19:21:20.077     GL_EXT_blend_minmax
    2022-01-11 19:21:20.077     GL_EXT_blend_subtract
    2022-01-11 19:21:20.077     GL_EXT_clip_volume_hint
    2022-01-11 19:21:20.077     GL_EXT_debug_label : NOT INITIALIZED
    2022-01-11 19:21:20.077     GL_EXT_debug_marker
    2022-01-11 19:21:20.077     GL_EXT_draw_buffers2
    2022-01-11 19:21:20.077     GL_EXT_draw_range_elements
    2022-01-11 19:21:20.077     GL_EXT_fog_coord
    2022-01-11 19:21:20.077     GL_EXT_framebuffer_blit
    2022-01-11 19:21:20.077     GL_EXT_framebuffer_multisample
    2022-01-11 19:21:20.077     GL_EXT_framebuffer_multisample_blit_scaled
    2022-01-11 19:21:20.078     GL_EXT_framebuffer_object
    2022-01-11 19:21:20.078     GL_EXT_framebuffer_sRGB
    2022-01-11 19:21:20.078     GL_EXT_geometry_shader4
    2022-01-11 19:21:20.078     GL_EXT_gpu_program_parameters
    2022-01-11 19:21:20.078     GL_EXT_gpu_shader4
    2022-01-11 19:21:20.078     GL_EXT_multi_draw_arrays
    2022-01-11 19:21:20.078     GL_EXT_packed_depth_stencil
    2022-01-11 19:21:20.078     GL_EXT_packed_float
    2022-01-11 19:21:20.078     GL_EXT_provoking_vertex
    2022-01-11 19:21:20.078     GL_EXT_rescale_normal
    2022-01-11 19:21:20.078     GL_EXT_secondary_color
    2022-01-11 19:21:20.078     GL_EXT_separate_specular_color
    2022-01-11 19:21:20.078     GL_EXT_shadow_funcs
    2022-01-11 19:21:20.078     GL_EXT_stencil_two_side
    2022-01-11 19:21:20.078     GL_EXT_stencil_wrap
    2022-01-11 19:21:20.078     GL_EXT_texture_array
    2022-01-11 19:21:20.078     GL_EXT_texture_compression_dxt1
    2022-01-11 19:21:20.078     GL_EXT_texture_compression_s3tc
    2022-01-11 19:21:20.078     GL_EXT_texture_env_add
    2022-01-11 19:21:20.078     GL_EXT_texture_filter_anisotropic
    2022-01-11 19:21:20.078     GL_EXT_texture_integer
    2022-01-11 19:21:20.078     GL_EXT_texture_lod_bias
    2022-01-11 19:21:20.078     GL_EXT_texture_rectangle
    2022-01-11 19:21:20.078     GL_EXT_texture_shared_exponent
    2022-01-11 19:21:20.078     GL_EXT_texture_sRGB
    2022-01-11 19:21:20.078     GL_EXT_texture_sRGB_decode
    2022-01-11 19:21:20.078     GL_EXT_timer_query
    2022-01-11 19:21:20.078     GL_EXT_transform_feedback
    2022-01-11 19:21:20.078     GL_EXT_vertex_array_bgra
    2022-01-11 19:21:20.078     GL_APPLE_aux_depth_stencil
    2022-01-11 19:21:20.078     GL_APPLE_client_storage
    2022-01-11 19:21:20.078     GL_APPLE_element_array
    2022-01-11 19:21:20.078     GL_APPLE_fence
    2022-01-11 19:21:20.078     GL_APPLE_float_pixels
    2022-01-11 19:21:20.078     GL_APPLE_flush_buffer_range
    2022-01-11 19:21:20.078     GL_APPLE_flush_render : NOT INITIALIZED
    2022-01-11 19:21:20.078     GL_APPLE_packed_pixels : NOT INITIALIZED
    2022-01-11 19:21:20.078     GL_APPLE_pixel_buffer
    2022-01-11 19:21:20.078     GL_APPLE_rgb_422
    2022-01-11 19:21:20.078     GL_APPLE_row_bytes
    2022-01-11 19:21:20.078     GL_APPLE_specular_vector
    2022-01-11 19:21:20.078     GL_APPLE_texture_range
    2022-01-11 19:21:20.078     GL_APPLE_transform_hint
    2022-01-11 19:21:20.078     GL_APPLE_vertex_array_object
    2022-01-11 19:21:20.078     GL_APPLE_vertex_point_size : NOT INITIALIZED
    2022-01-11 19:21:20.078     GL_APPLE_vertex_program_evaluators
    2022-01-11 19:21:20.078     GL_APPLE_ycbcr_422
    2022-01-11 19:21:20.078     GL_ATI_separate_stencil
    2022-01-11 19:21:20.078     GL_ATI_texture_env_combine3
    2022-01-11 19:21:20.078     GL_ATI_texture_float
    2022-01-11 19:21:20.078     GL_IBM_rasterpos_clip
    2022-01-11 19:21:20.078     GL_NV_blend_square
    2022-01-11 19:21:20.078     GL_NV_conditional_render
    2022-01-11 19:21:20.078     GL_NV_depth_clamp
    2022-01-11 19:21:20.078     GL_NV_fog_distance
    2022-01-11 19:21:20.078     GL_NV_fragment_program_option
    2022-01-11 19:21:20.078     GL_NV_fragment_program2
    2022-01-11 19:21:20.078     GL_NV_light_max_exponent
    2022-01-11 19:21:20.079     GL_NV_texgen_reflection
    2022-01-11 19:21:20.079     GL_NV_texture_barrier
    2022-01-11 19:21:20.079     GL_NV_vertex_program2_option
    2022-01-11 19:21:20.079     GL_NV_vertex_program3
    2022-01-11 19:21:20.079     GL_SGI_color_matrix
    2022-01-11 19:21:20.079     GL_SGIS_generate_mipmap
    2022-01-11 19:21:20.079     GL_SGIS_texture_edge_clamp
    2022-01-11 19:21:20.079     GL_SGIS_texture_lod
    2022-01-11 19:21:20.079 OpenGL features for current hardware:
    2022-01-11 19:21:20.079     OpenGL provider: Apple
    2022-01-11 19:21:20.079     OpenGL renderer: Apple M1
    2022-01-11 19:21:20.079     OpenGL version: 2.1.0
    2022-01-11 19:21:20.080     Maximum number of lights: 8
    2022-01-11 19:21:20.080     Number of auxiliary buffers: 0
    2022-01-11 19:21:20.080     Number of texture units: 8
    2022-01-11 19:21:20.081     Depth buffer bit resolution: 32
    2022-01-11 19:21:20.081     Maximum OpenGL texture size: 16384 x 16384
    2022-01-11 19:21:20.081     Current OpenGL Texture Quality Setting: Best Performance
    2022-01-11 19:21:20.081     RGBA color bitplane resolutions: 8 8 8 8
    2022-01-11 19:21:20.082     Shadow mapping supported
    2022-01-11 19:21:20.082     VBO supported
    2022-01-11 19:21:20.082     GL_MAX_ELEMENTS_INDICES : 150000.
    2022-01-11 19:21:20.082     GL_MAX_ELEMENTS_VERTICES : 1048575.
    2022-01-11 19:21:20.181 Creating Asset Manager...
    2022-01-11 19:21:21.456 Connected to CMS: PostgreSQL 9.3.4 on x86_64-apple-darwin, compiled by i686-apple-darwin11-llvm-gcc-4.2 (GCC) 4.2.1 (Based on Apple Inc. build 5658) (LLVM build 2336.9.00), 64-bit
    2022-01-11 19:21:22.322 Creating Cloud Manager...
    2022-01-11 19:21:22.362 Creating Authentication Manager...
    2022-01-11 19:21:22.408 Creating Scene...
    2022-01-11 19:21:22.412 *** Scene Cleared ***
    2022-01-11 19:21:22.425 Creating Inverse Kinematics Manager...
    2022-01-11 19:21:22.431 Loading plug-ins:
    2022-01-11 19:21:22.437     libaniMate2.dylib
    2022-01-11 19:21:22.496     libdazscriptide.dylib
    2022-01-11 19:21:22.520     libdzalignace.dylib
    2022-01-11 19:21:22.529     libdzassetiofilters.dylib
    2022-01-11 19:21:22.551     libdzautofit.dylib
    2022-01-11 19:21:22.568     libdzautoriggerbasic.dylib
    2022-01-11 19:21:22.577     libdzautoshaderbakeractions.dylib
    2022-01-11 19:21:22.587     libdzbrycebridge.dylib
    2022-01-11 19:21:22.597     libdzbvh.dylib
    2022-01-11 19:21:22.606     libdzcolladax.dylib
    2022-01-11 19:21:24.728     libdzcomponents.dylib
    2022-01-11 19:21:24.749     libdzcontentlibrarypane.dylib
    2022-01-11 19:21:24.757 Updated metadata for 0 of 1 items.
    2022-01-11 19:21:24.758     libdzcr2exporter.dylib
    2022-01-11 19:21:24.768     libdzcustomizedlg.dylib
    2022-01-11 19:21:24.790     libdzdelightrenderer.dylib
    2022-01-11 19:21:24.822     libdzdformeditor.dylib
    2022-01-11 19:21:24.833     libdzdynamics.dylib
    2022-01-11 19:21:26.023 WARNING: /src/sdksource/cloud/dzcloudtasknotifier.cpp(660): sync completed successfully, 1 items succeeded, 0 items failed.
    2022-01-11 19:21:26.024 Metadata update succeeded.
    2022-01-11 19:21:26.025     libdzeasyloader.dylib
    2022-01-11 19:21:26.032     libdzexpexporter.dylib
    2022-01-11 19:21:26.044     libdzfbxexporter.dylib
    2022-01-11 19:21:27.099     libdzfbximporter.dylib
    2022-01-11 19:21:27.108     libdzfiguresetup.dylib
    2022-01-11 19:21:27.123     libdzfilamentdrawstyle.dylib
    2022-01-11 19:21:27.134     libdzhexagonbridge.dylib
    2022-01-11 19:21:27.142     libdzimageio.dylib
    2022-01-11 19:21:29.302     libdzirayrenderer.dylib
    2022-01-11 19:21:29.330     libdzjointeditor.dylib
    2022-01-11 19:21:29.349     libdzlayerededitor.dylib
    2022-01-11 19:21:29.361     libdzlayerfilter.dylib
    2022-01-11 19:21:29.374     libdzmacvideo.dylib
    2022-01-11 19:21:29.381     libdzmanualshaderbaker.dylib
    2022-01-11 19:21:29.391     libdzmaptransfer.dylib
    2022-01-11 19:21:29.401     libdzmorphfollower.dylib
    2022-01-11 19:21:29.411     libdzmorphloader.dylib
    2022-01-11 19:21:29.424     libdzmorphloaderpro.dylib
    2022-01-11 19:21:29.439     libdzobjexporter.dylib
    2022-01-11 19:21:29.445     libdzoptitexclothbasic.dylib
    2022-01-11 19:21:30.147     libdzpolygongroupeditortool.dylib
    2022-01-11 19:21:30.162     libdzprimitives.dylib
    2022-01-11 19:21:30.170     libdzpropertyhierarchyeditor.dylib
    2022-01-11 19:21:30.183     libdzpuppeteer.dylib
    2022-01-11 19:21:30.194     libdzpz3importer.dylib
    2022-01-11 19:21:30.202     libdzrenderedit.dylib
    2022-01-11 19:21:30.210     libdzrenderlibrary.dylib
    2022-01-11 19:21:30.216     libdzrslshadercompiler.dylib
    2022-01-11 19:21:30.222     libdzsavefilters.dylib
    2022-01-11 19:21:30.243     libdzscriptedrenderer.dylib
    2022-01-11 19:21:30.254     libdzscriptedsteps.dylib
    2022-01-11 19:21:30.266     libdzshaderbaker.dylib
    2022-01-11 19:21:30.275     libdzshaderbuilder.dylib
    2022-01-11 19:21:30.288     libdzshadereditor.dylib
    2022-01-11 19:21:30.295     libdzshadermixerbase.dylib
    2022-01-11 19:21:32.446     libdzshadermixergui.dylib
    2022-01-11 19:21:32.461     libdzsmartcontentpane.dylib
    2022-01-11 19:21:32.469     libdzspotrendertool.dylib
    2022-01-11 19:21:32.476     libdzstrandbasedhaireditor.dylib
    2022-01-11 19:21:32.713     libdztextureatlas.dylib
    2022-01-11 19:21:32.725     libdztimeline.dylib
    2022-01-11 19:21:32.735     libdztransferutility.dylib
    2022-01-11 19:21:32.746     libdzu3dexporter.dylib
    2022-01-11 19:21:32.753     libdzweightmapbrush.dylib
    2022-01-11 19:21:32.767     SDK_SceneInfoPane.dylib
    2022-01-11 19:21:32.775     libdzdrawstyles.dylib
    2022-01-11 19:21:32.784     libdzpowerpose.dylib
    2022-01-11 19:21:32.808 Error writing author data.
    2022-01-11 19:21:32.841 Total class factories: 2071
    2022-01-11 19:21:32.844 Creating Script Engine...
    2022-01-11 19:21:32.889 Creating Main Window...
    2022-01-11 19:21:32.896 Creating Viewport Manager...
    2022-01-11 19:21:32.939 Successfully created OpenGL viewport for Viewport1.
    2022-01-11 19:21:32.970 Successfully created OpenGL viewport for Viewport2.
    2022-01-11 19:21:32.981 Successfully created OpenGL viewport for Viewport3.
    2022-01-11 19:21:32.988 Successfully created OpenGL viewport for Viewport4.
    2022-01-11 19:21:33.114 Creating Action Manager...
    2022-01-11 19:21:33.144 Creating Pane Manager...
    2022-01-11 19:21:33.574 Successfully created OpenGL viewport for AuxViewportView.
    2022-01-11 19:21:35.611 Executing startup script...
    2022-01-11 19:21:35.626 Started in: /Users/Chris/Daz 3D/Applications/DAZ 3D/DAZStudio4 64-bit
    2022-01-11 19:21:35.626 DAZ Studio Started
    2022-01-11 19:21:35.629 Creating Pixel Buffer
    2022-01-11 19:21:35.634 Pixel buffer - Width: 1024 Height: 1024
    2022-01-11 19:21:35.639 Compiling OpenGL Shader...
    2022-01-11 19:21:35.657 Fragment Shader:
    Fragment Shader compiled successfully.
    Linking Shader:
    Shader Program successfully linked.
    edited January 2022
    OK,you do miss a vital part if the startup:
    2022-01-10 15:00:29.412 Error writing author data.
    2022-01-10 15:00:29.633 Initializing NVIDIA Iray...
    2022-01-10 15:00:29.633 Iray [INFO] - API:MISC ::   0.0   API    misc info : Loaded "/Applications/DAZ 3D/DAZStudio4 64-bit/libs/iray/libneuray.so"
    2022-01-10 15:00:29.633 Iray [INFO] - API:MISC ::   0.0   API    misc info : Iray RTX 2020.1.6, build 334300.9558, 27 Mar 2021, macosx-x86-64
    2022-01-10 15:00:30.681 NVIDIA Iray GPUs:
    2022-01-10 15:00:30.681 NVIDIA Iray Scheduling Configuration:
    2022-01-10 15:00:30.681     CPU Load Limit: 24
    2022-01-10 15:00:30.681     CPU Thread Affinity: disabled
    2022-01-10 15:00:30.681     GPU Load Limit: 1
    2022-01-10 15:00:30.978 Total class factories: 2200
    Are yu sure you do not have any Anti-Virus software that has decided to remove the nVidia libs?
    If you check under /Applications/DAZ 3D/Studio 4, do you have the Iray libs there at all?
    361 x 669 - 67K
    No anti-virus and the files in that Iray folder seem to match up for the most part.
    297 x 744 - 68K
    edited January 2022
    Next - do IRAY show up in installed plugins and is it checked?
    624 x 231 - 33K
    301 x 425 - 201K
    Above, Richard had suggested checking that as well.  Yes, it's there, checked and green.  Every plug-in is showing checked and Green.
    If you just add a sphere and hit Render, still getting that message?
    Just checking if it's that you are rendering something too big for you RAM.
    Yes, same thing.  I even get it when there are no objects loaded.  I know it's not a RAM thing, I've rendered many large projects.
    OK, this was a tricky one, specially as your log clearly states no Iray as loaded. If you try 3Delight, same thing? Just to see where the error is.
    Actually, that seemed to work fine... well, it rendered at least, but for some reason, the figures' textures were all white.  Clothes and hair looked fine.
    edited January 2022
    OK, then it's bound to Iray render then. The  white chars is usually when rendering Iray skins in 3DL
    Any ideas?  I tried unchecking IRAY in plugins and then checking it off again.  Notta!
    Really weird issue. As they were not loaded (log said so), but at the same time they are said to be "ok" in the about plugins.
    What Hardware are you running on?
    edited January 2022
    M1 Mac Mini. 16G  OS12.0.1.
    I just don't get what 'broke.'  Everything was running fine... unless something updated and caused an issue.
  • Same issue. Suddenly overnight no renderer Nvidia Iray availble.
    No updates or anything like that undertaken. Just doesn't work anymore.
    Daz Studio 4.16
    10.15.7 MacOs
  • Lee MoonLee Moon Posts: 941
    I'm having the same "unable to render" error message.  I rendered in Iray this morning, shut down, came back after lunch and can no longer get an Iray preview nor Iray render.
    M1 iMac, DAZ Studio 4.15.0.30, macOS 11.6.6
    Lee
    edited June 2022
    Also, I have an Intel i9 MacBook Pro, macOS 10.15.7, DAZ Studio 4.12.0.86 that is giving the same "unable to render" message when attempting an Iray render.  I haven't used this Mac for DAZ Studio rendering in many weeks.
    Neither the MacBook Pro, nor the M1 iMac have had any recent system or software updates.
    At this point, DAZ Studio and all my assets are useless on 2 Macs, with the same error.  What the heck is going on?
    Lee
    Post edited by Lee Moon on
    Another data point: I can successfully perform Iray renders/previews on my M1 MacBook Air, macOS 11.6.5 (an earlier version than the M1 iMac), DAZ Studio 4.20.0.6 and DAZ Studio 4.16.0.3 (don't recall which one is production version vs. public beta.)
    So, 2 out of 3 Macs running older versions of DAZ Studio (pre-4.16.x.x) are throwing the "unable to render" error when attempting Iray renders/previews.
    I have just completed a macOS security update on the MacBook Pro (Intel) to see if that helped, but DAZ Studio will still not Iray render.
    Lee
  • dabodabo Posts: 5
    Same problem. Woke up this mornning DAZ wouldn't render or give me any Iray preview anymore. How do I solve this?
    I updated my DAZ Studio beta version to 4.20.1.38 (latest available one as of today.). Iray rendering works fine with it and I assume the current production version as well.
    I'm keeping my "broken" version of DAZ Studio in case there's an easy fix, but I'm now using the beta build in order to render again.  I had to recreate all my ghost lights due to changes in Iray between my older DAZ Studio versions and the newer/newest versions.
    Not the preferred solution, but at least I can do Iray previews and Iray renders again.
    Lee
    I sent in a help desk ticket a few minutes ago describing the Iray issue.  Others might need to do the same with specifics on their hardware, macOS version, DAZ Studio version to help the DAZ team track down the problem.
    Lee
  • Encountered the same issue today, using Daz Studio 4.15 on macOS Monterey. Nothing was updated or changed since yesterday, so this problem happened for no apparent reason. Had no other choice but to upgrade to Daz 4.20. Rendering "works" on 4.20 for me, but it is much much slower.
