help with manual setting x y z object angles
Is there a manual setting for X Y Z angles in an object? Say I make a plane and I want to rotate it on the X axis to 90 degrees. Can I set that manually because trying to do it by mouse or pad brings me close but not on target.
Click the number on the slider in the Parameters or Posing panes to get a numeric edit field.
