Bend mode
juanjoharojuanjoharo Posts: 92
Hi... is there any way to bend clothes in another ways than the normal bend?
For example, bending a pant leg between the knee and the pelvis, to put this in a chair... (not using dynamic clothes)
Thanks
  • Richard HaseltineRichard Haseltine Posts: 112,067
    DForms would let you do that - select the item, ideally in its zero pose, and then go to Create>New Dform. Adjust the Field so it encloses the bits you want to bend, place the base at the hinge-point, and rotate the actual DForm node. You can also use a weight-map to control the DForm, instead of the field, for finer adjustment.
