Automate aging
Hi guys
i want to animate aging a model. I see sliders available to do this. Is there anyway to script this ?
ie set the slider from min to max over 10 mins and render the animation ?
thanks in advance.
Hi guys
thanks in advance.
You shouldn't need to use a script - just open the Timeline pane (Window>Panes(Tabs)>Timeline), assuming it is in Advanced mode make sur that Types is set to TRSOA, and click the Add keyframe button (key icon with a +), then drag the play head to the last frame and set the morph value to 1 (or 100%, depending on its display settings).
