saving pose so the figure does not jump to zero location
i have followed what i am supposed to do, as i remember soetimes it worked sometimes not-the goal is to pose the fiogure in desired pose at the present location they are, all that should change is the pose not the location of the figure (which of course can be anywhere from a foot to 300 feet away from daz zero point) please tell me how to do this succesfully , this has been a huge issue for a  long time , thanks
  • Pose the figure using bones, move the figure using the figure node, save both (ideally as separate presets so you can still use the pose in other places).
  • VicSVicS Posts: 1,273
    Thanks Ricahrd, dont realy know what you mean except for saving both seperately-both saved as pose preset
    --how do I pose figure using bones, now im using parameters and transform tool
    which is a figure node?
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
    i think i remrember i tried that way before -ill try it , let you know, thanks
    Richard's way works, when pose is saved uncheck the characer and only check hip instead, so nice and easy
