Loading/creating screen light has changed !!
Hi all
Hope someone can help. I am getting back into Daz studio again after a couple of years away and having to start all over again.
After loading this model/figure then looking at another, clicking new after each. I noticed that the light in the Loading/creating screen had changed tyo a very bright light with a blue tint !!
And the render camera has also changed and nolonger gives the same view as the Loading/creating screen
anyone know how I can change it back to the warmer and less bright light I had before?
as always thanks again
  • Which Drawstyle are you using? I think you may have Filament in the bluish one, and I think you are switching between activity tabs when you see the other - which is using a different Drawstyle. You see/set the Drawstyle through the sphere icon next to the camera/view picker button (it probably says Perspective View or Camera 1).
  • thanks for the fast reply.
    I will check it out
    Are you using Daz Studio 4.15 or 4.16?
    If its 4.16, are you using a mesh light that uses an EXR file in the Luminous channel?
  • Hi
    I am using Daz 4.16.
    Thanks to Richard, I have fixed the camera problem
    But the light is still wrong, to bright and very light blue.
    "are you using a mesh light that uses an EXR file in the Luminous channel?" I have no idea.
    As I said I am getting back into this and starting from the ground floor again.
    If it is that how do I find itt and fix it? please.
    thanks again all
