Dynamic clothing, is there a way to make some?
michaelolsonmichaelolson Posts: 117
Anyone know how I can make my own dynamic clothing and cloth? Thanks.
«1
    Depends on which program. Daz Studio's dynamic system is proprietary so only Optitex can make it. Poser can use a regular OBJ in the cloth room.
    edited March 2015
    Carrara has some cloth through softbody physics, but users have found that calculation times are abysmal unless the cloth only interacts wih other cloth - which is achieved by creating softbody attach panels as "underwear" for the clothed figure. Just uncheck visibility for the undersuit. It is very much still in the early stage as people determine best practices for creating the softbody attach undersuit and best settings for different types of fabric (leather reacts differently than cotton). But it does work, and I occasionally use it in my workflow in places that I used to rely on export of objs created in Poser's cloth room. Definitely not perfect.
    For animations
    - an example of how the underwear/undersuit works is here
    https://www.youtube.com/watch?v=FfKfiP5YTto&feature=youtu.be
    - and an example of how draped Carrara cloth over an animated figure with invisible undersuit is here
    http://www.daz3d.com/forums/discussion/49954/P360/#765003
    Here is an example of draped cloth in Carrara, but you can make the fabric more stiff like leather or less stiff by adjusting settings.
    http://www.daz3d.com/forums/discussion/49954/P285/#763180
    For stills, you can see two examples of rather stiff looking cloth for A3 here (just a test render of a skin shader but the skirt is draped over a bent leg).
    http://www.daz3d.com/forums/discussion/53931/#785984 (edit: this example is actually a morphed Genesis 2 female)
    and here
    http://www.daz3d.com/forums/discussion/49954/P195/#757931
    with the undersuit construction for the second example demonstrated here
    http://www.daz3d.com/forums/discussion/49954/P195/#758041
    You can see the same concept applied for a long skirt for a custom genesis figure here
    http://www.daz3d.com/forums/discussion/49954/P210/#758514
    A quick guide to links explaining some of the concepts for applying this cloth to posed figures and animated figures in Carrara is here
    http://www.daz3d.com/forums/discussion/49954/P210/#758192
    Post edited by Diomede on
    The Carrara examples above were generally constructed with user-made custom clothing items, but I have applied the same technique to some purchased content designed for V4. However, sometimes the objs for purchased items are not ideal for Carrara if they were designed for Poser (things like buttons and accessories may be designed for settings in Poser that would have to be addressed differently in Carrara, for example).
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,506
    . . . . and then there is the 10K+ Optitex software :snake:
  • ghastlycomicghastlycomic Posts: 2,531
    If it's for your own personal use you can modify an uncompressed .duf file to enable dynamic cloth but if the original mesh wasn't created with dynamic draping in mind the results might not be acceptable.
    Something else to play with....:lol:
  • AbbyCloneAbbyClone Posts: 99
    This is probably a stupid question but why doesn't Daz purchase this software from Optitex?
    and more $$$$$$$$
    Basically, it is a piece of high-end clothing design software that someone found a secondary use for and saw $$ with a plugin...but the $$ never materialized, so things have languished in limbo.
    And since fashion design houses will and can shell out $10K to use the full features, I don't think Optitex will be willing to part with it, cheaply, if at all.
  • ZilvergrafixZilvergrafix Posts: 1,385
    People always complaints for new abilities not present on Daz Studio, if, in a future, the ability to create your own cloth inside Studio would be available, peolpe will complaint for another new feature not present, and so on...
    Optitex software is not easy to manage for an entry level 3d artist, even if available you will need read the whole manual for even make a f*** trouser!
    had you seen the freebies on the Optitex site?
    and more $$$$$$$$
    So there's not a big enough demand for dynamic clothing to justify Daz or a PA forking out $10k+ for Optitex's 3d suite?
    No, there is not...and the $10K still doesn't exactly get working clothing into DS...there's a lot of extra work with DS specific stuff that the Optitex software doesn't do.
    None of the vendors ever want to give out actual numbers, but they will all tell you that to make $10K you need to sell an awful lot of stuff...and looking at my freebies (nothing to do with dynamic clothing) downloads, it took nearly 3 yrs for the most popular one to hit 1000 downloads. And if I was making $10 off each one, it take 3 yrs to recover the cost of the software...I, like most other vendors, don't see that as worth it.
    So you've got the regular 'development' work PLUS making it dynamic with expensive software.
    What's stopping them from dumping Optitex entirely and go with a system that allows the use of regular OBJ files?
  • HavosHavos Posts: 5,703
    Nothing, I believe, except that a fully working dynamic system would cost thousands in development costs, with no real certainty of a pay back on that. Dynamics is not some simple plug in, it is a major programming task, and not something you take on lightly. I remember reading in a thread months back that one (or maybe it was two) vendors were intending on developing their own plugin, but only time will tell if these will ever materialise.
    +1,000,000,000...
    Seriously, that's the best option. But there's something, somewhere that's stopping it...whether it is just lack of sales or something else, I've got no idea.
    nVidia physX inc Apex cloth should be implementable like Iray but I also suspect some sot of agreement with Optitex might be in place stopping it, nobody knows but DAZ.
    Bullet is free...and in Carrara...
    + carrara has dynamic hair that moves
    Ghastly's hint had me intrigued enough to whip out notepad but no luck thus far finding exactly what I need to change, just get errors and I guess he cannot elaborate for legal reasons.
    speculation: maybe iz optitex paying daz
    edited March 2015
    "O" that is subscription based as well, like the new PhotoJunk rent-ware. That is NOT a one time fee.
    Also, you would need an OBJ file, for each possible variation in the figure shape (and including combination OBJs as well). How many possible combinations of the G2M base figure shaping dials are there, lol. Tall 0.1%, Tall 0.2%, Tall 0.1% & Thin 0.1%, etc...
    Never mind, not worth the asking price.
    I have Hexagon, and Blender, good enough for my needs. And the Daz Studio D-form for getting skirts to behave in dancing poses.
    edited March 2015
    who, what! How did I miss that!
    I wanted the Addison Hair style. Converted for G2F and ported to Daz Studio for about a year now.
    https://www.daz3d.com/addison-hair-for-carrara
    That is dynamic in Carrara? Is it any hair, or just stuff made for Carrara, or stuff made to be dynamic in Carrara?
    that one might fly around a bit animated , is meant for draping but yes
    edited March 2015
    https://www.youtube.com/watch?v=lyqebEYxzTk I find fur easier than hair, esp long hair, is very wild and jittery, you paint it on and simulate it
    note I did postwork that with slomovideo
    edited March 2015
    There's a tutorial on it over at Renderosity.
    Whoops that wasn't the right tutorial. Let me see if I can find it.
    Post edited by ghastlycomic on
    carrara hair isn't gonna work in ds. haz it's own hair tools
    utooby long drape hair for ca https://www.youtube.com/watch?v=4C90KA0_-9U
    Hmmm... so looking into it it would seem Daz broke something after v4.7 so that you cannot manually create a dynamic mesh anymore.
    I wonder if this effects the performance of the legitimately purchased dynamic cloth in any way.
  • erik leemanerik leeman Posts: 262
    They most definitely spent some time working on it, draping dynamic cloth never worked as good as it does now (v4.7).
    In recent previous versions it had turned into an horrendous crash-fest that took forever to get something done, if ever, now it works like a dream. Ugly things like self-intersections, bunched up crumpled knots, and sinking collars still happen far too often, but not crashing all the time is a huge improvement!.
    Still haven't tried that script hack, so I don't know whether it still works or not, but with all the (partly free or 70% discounted) dynamic clothing I have collected over time there really wasn't much urgency to do so, only curiosity.
    Erik
    Quite frankly it is not hard to do it in Poser, run the dyntomorph python script and save a pz3 and import it if you really want it in DAZ.
    Or in my case import into Carrara where I freeze and import Optitex stuff anyway.
    I too was curious and am more interested in the "why not" of a different cloth system being implimented and because of this "hack" thinking Optitex "Hardcoded" into DAZ and another system could break that.
    The hack only raises more big questions for me if anything.
  • BejaymacBejaymac Posts: 2,002
    After the exploit was brought to their attention DAZ changed the system to stop self made dynamics from being recognized by the plugin, I think it was the last version of 4.6 that it appeared in, it's still possible to get them to work with a workaround, but as I've already had one post deleted on the subject that's as far as I'm going on it.
    As for why stick with Optitex, could it be that both companies are owned by the same faceless mega corp, after all back when it was announced we were getting dynamics DAZ were also in the middle of a "merger".
    Thanks wendy♥catz and
    This has me curious if there is even a system anywhere for making Daz Studio Dynamic cloths. The Optitex 3D Suite is not for making Daz Studio content, not by a long shot. It can't even export anything that Daz Studio can comprehend.
    So legitimately, what is the legal way to make Dynamic stuff in Daz Studio? What programs? Where do I get them? ALL of the stuff that I will need to making Daz Studio Dynamic Cloths, not some other system for sowing machines and cloth mills.
