Impossible to do the poses of the male and female together
Hi,
I have recently acquired some poses of the male and female but I did not succeed
Can you tell me how to make the male and female have the poses together like on the pictures of the sale sheet?
Thank you
  • LeanaLeana Posts: 13,517
    What set is that? Different pose sets can work in different ways.
  • charlescharles Posts: 866
    Poses don't usually get you exactly where you want to be. I use them as tools to get me from 60 to 99% of where I want to be then tweak the rest.
    If your problem is that they aren't anywhere close or facing the right way, then you need to do this. Unparent them if they are and then ZERO out the current pose.
  • I often use commercial poses, they are a great starting point but a lousy finishing point. Almost all commercial poses asume that you're using standard figures. As none of my figures are exactly standard shape the pose will almost always need a bit of tweaking.
    Also as Charles commented above, they are designed for figures starting at the zero position. So therefore make sure that your figures are zeroed in both translation and rotation. Then apply the poses. After that I either parent one figure to the other (or create a group for them both), that then enables me to easily move them as a couple to the part of the scene that I actually want them in.
