Morph problems with Daz Studio 4.7
I have exported a Wardrobe then made some morph-changes and used Morph Loader Pro to add some morphs.
It was not successful. Got the message " Warning: Geometry did not match, failed to create morph. "
I know, why this happens....
I tried this again (without any changes) with different programs: 3dsMax, Cinema, and Silo.
Got the same message over and over again.
If I do this with the exported original file from Daz Studio, I get the message:
" No deltas for morph, skipping node. Created morph successfully. "
Same message - if I try this with ZBrush.
No morphs are then shown in the Parameters Tab.
Made then different export settings in Daz studio 4.7, tested all again - always the same result.
For a long time before, I created successful a lot of morphs with Daz Studio 4.6.
I WANT MY DAZ STUDIO 4.6 BACK !!!
Is there a way to go back to Version 4.6 ???
  • Richard HaseltineRichard Haseltine Posts: 112,037
    Does the object you export include only a single item - the clothes you want to morph? If you then load the base figure, or something else, as a guide in the modeller do you make sure it is not in the morph OBJ? Do you have SubD applied to the clothes, and if you do do you reset the mesh resolution to base before exporting?
  • edited December 1969
    I have found the mistake !
    Have forgotten to deactivate the check box "Write Groups"
    Thanks for your effort !!!
