Align points on a ring
PinzelmeisterPinzelmeister Posts: 114
edited December 1969 in Hexagon Discussion
I thought I knew how to do this . . . saw it in a tutorial or something. I just want to align these points - i.e. so they are on a flat surface (Y coordinates all the same). When I select all of them and enter a new Y coordinate Hexagon just moves all of them equal amounts instead of aligning them. So . . . how do I do this?
1002 x 197 - 72K
  • m_m_italym_m_italy Posts: 396
    Bye
    1346 x 562 - 61K
  • Wee Dangerous JohnWee Dangerous John Posts: 1,605
    edited March 2015
    Just in case you cannot see what M_M has done, (you can do this with either points or edges, but easier to explain with edges) select the top edge, press L to loop the selection. In the Properties tab, change the size (as shown by M-M) to 0.000. You where nearly there, just had the size and the position mixed up, have a play with the Universal Manipulator while doing this operation and the properties tab will show you what is happening (move the green cube up and down while you're holding down your left mouse button).
    Using points, you can select individual points or use the "Convert selection to Points" in the Selection menu.
    Hope this helps - John
    481 x 243 - 35K
    Post edited by Wee Dangerous John on
    I was just wondering this same, thanks!
