Handling Visiblity toggle in animations for clothes
I'm trying to make a series of images, a comic if you may, and between 2 frames, I need a piece of clothing to disappear. I've been working on this for a few days. I've hit a wall now, I can't think of anything that is practical.
- The visibility flag is not keyframed.
- Surface Ambient opacity strength isn't keyframed either.
- Visibile in render seems iffy, and adds disparity and confusion to the viewport.
- Can't scale down a piece of clothing.
- Can't transform it under the ground plane, since it's fit to the figure.
- Doing canAnimate on the visiblity property works for the session, but isn't saved in the scene, so reloading the scene requires re-running the script and adjusting all the items again.
Anyone got ideas ?
I'dd love to see visiblity keyframed in the next 4.8 beta or 5.0.
have a look at this
https://sites.google.com/site/mcasualsdazscripts/matanim
be sure to have the clothing not "fit to" while running the script
it will work
So it lets me "animate" the opacity of a texture ?
What happens if "Fit to" is enabled for this script ?
for me it does not work then
unfit the garment
run the script
select the surface in the script
animate the opacity in the timeline
then fit it again and the animation should work
Looks like this has the same issue as the script I wrote that uses canAnimate.
The "canAnimate" flag is not saved in the scene file, so if you save, close DAZ Studio, then reload, it's not animated anymore.
now look here
https://sites.google.com/site/mcasualsdazscripts4/mcjanimatsave
I was googling yet again hoping for a working solution for this problem, and found your thread...
Me too! This has to be one of the most-often-sought features that has been ignored by the DS developers. PLEASE ANIMATE VISIBLE!
On further (re)testing, I see that Visible in Render does animate and does have the intended effect on a render, I guess I either missed that or dismissed it.
There is a trick to making it work. Start at the frame before where you want the node to disappear, and toggle the Visible in Render setting off and back on. That sets a key on the prior frame to keep the thing visible up to that point. Then frame forward and turn it off.
Still, it is very unintuitive. And if you want to use it to swap out items (e.g. change hats, or have an item that briefly glows, or such) the scene will be incomprehensible in the viewport.
I just wrote myself a little plugin called AniVis that adds an item to the Edit menu to let you add a new persistent animated boolean property to any node, and then checks the current values of those properties whenever the current frame changes; it changes the value of (non-animated) Visible based on the value of AnimateVisible in the current frame; like Visible in Render it toggles things on and off frame-by-frame, but unlike the builtin property it lets me see what is happening in the viewport while I'm working on the scene..
If there's enough interest I guess I could find some way to make it available.
