Daz Studio set-up
andrushuk1andrushuk1 Posts: 343
edited December 2021 in Daz Studio Discussion
Hi , I'm not sure if this is the right place to ask for this but here it is , I use the HollyWood Blvd layout and at the top there are 4 tabs (1) Actors , Wardrobe & Props  (2) Pose & Animate (3) Lights & Cameras (4) Render .      would it be possible to have the (1)  made into three seperate tabs  actors , wardrobe and props so that these three have each their own tab.
  • Moved to Daz Studio Discussion as it is not a Product Suggestion.
    You can add new Activities ("tabs") in Window>Workspace>Customise - right-click in the Activities tab on the right, which allows you to create an activity and enable or disable toolbars. You can create additional toolbars in the Toolbars tab, by dragging things across from the list of actions on the left. Once you have the activity you can then use Window>Panes(Tabs) to populate it as desired..
  • Ok thanks a lot Richard
    smiley
