Atmospheric smoke camera
it says load camera then smoke planes
cannot locate a camera withiun the set or smoke planes every icon marked Materials
if someone has the link to the instructions, or is ther a way to get the instructions from any set, when i go to search on thatpage to enter sku there are never instructions i can find for any products
  • NorthOf45NorthOf45 Posts: 5,916
    edited December 2021
    Atmospheric Smoke Camera [Documentation Center]
    If you found the materials, you went right past the camera. Go back up one folder. The camera loads with three target planes to which you add the smoke materials.
    Post edited by NorthOf45 on
  • VicSVicS Posts: 1,273
    thanks, i cant believe i missed that, once i expanded the windows i can see everything now, i must be hard of seeing, thanks a lot
    The guides in iray preview are still there in render
    The smoke material should replace the guide texture. Can't check myself right now, disk problems...
    ok it doesnt happen all the time
