iray HDR+Eyes
When i'm using an HDR as an enviroment map it always makes the eyes milky.When i'm using only spotlights the eyes look great.Using both as dome+scene still messes up the eyes.Is there any way to combine those 2 without getting the milky eyes?
Have you converted the character surfaces to Iray?
Yes all of them
ok.. Select the cornea and the eye surface and apply the iray thin water shader preset. Set refraction index on the cornea about 1.37 and I suggest that you increase the corneal bulge morph so that the cornea curves realistically. See if that helps.
Holy sh*t that worked!!!Thank you so much Khory!
Glad to hear that sorted it. Love an easy fix!
The real number is 1.376 ;-)
If your going to be really picky.. 3 different parts of the cornea have different refraction indexes. That is why I said about...
