Denoiser failing with following error code
So I use the Denoiser with a lot of my renders, and this wasn't happening in the past but now (within the past few weeks) it's been failing with no notification whenever I have 3 characters in the scene and occasionally with only 2. there's no notification either, I just notice the noise in the render afterwards and whenever I check the log file the Error below is shown at the itteration I have set for the denoiser to kick in.
I have the RTX 2060 Super, bought it brand new at microcenter and it's only 1 year old.
I don't understand why this is happening now when I've been able to do this perfectly fine in the past with the same exact specs on my PC. I've rendered 4 characters multiple times with no issue with the Denoiser but now it's acting up for some odd reason. it also doesn't seem to matter what environment I use, a simple environment or a massive environment both have the same error at the point that I add in a 3rd character to the scene, and occasionally with 2, but never with 1, All are Gen. 8 models.
2021-12-28 20:23:14.710 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(359): Iray [ERROR] - POST:RENDER ::   1.0   POST   rend error: A CUDA error occurred: out of memory
2021-12-28 20:23:14.715 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(359): Iray [WARNING] - POST:RENDER ::   1.0   POST   rend warn : Failed to allocate device memory. Postprocessing will fall back to CPU.
2021-12-28 20:23:14.719 WARNING: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(359): Iray [WARNING] - POST:RENDER ::   1.0   POST   rend warn : denoiser is not available on CPU and will be disabled.
Any advice would be appreciated, and any questions you have for more clarification I'll glady answer, thank you in advance.
  • prixatprixat Posts: 1,627
    It's not always easy to tell what pushes a scene over the limit.
    I once had a single figure suddenly start falling back to CPU, it turned out to be the hair. I had applied subdivision to the hair at some point and that was enough!
    It took me ages to find that particular one, just by removing individual objects one at a time.
