Measure Metrics plugin failed to load error
DarkS474DarkS474 Posts: 154
Using Daz Studio 4.15.0.2 64-bit Pro
How to fix this ?
I get this error in the About Installed Plugins:
Plugin failed to load!
Filename :
C:/Program Files/DAZ 3D/DAZStudio4/plugins/dzmeasuremetrics.dll
Name :
dzmeasuremetrics
Author :
Unknown
Version :
0.0.0.0
Reason :
Plug-in was made for a newer version of DAZ Studio.
Post edited by DarkS474 on
  • AscaniaAscania Posts: 1,856
    Update D|S to the current version.
  • DarkS474DarkS474 Posts: 154
    Yes sure I could update but due to plenty of reported bugs on every new version I would like to make the plugin work without updating.
  • Ppeol,e tend to report issues to the forum, not so much smooth working (unless a particular issue that  they had has been resolved) so it always looks bad. You could try the Public Build, which won't affect the general reelase you are using (but the version of Iray in the current Public Build has made some significant changes in a couple of areas that stop some products from working as intended).
    And that will never go beyond wishful thinking. The version of the plugin available for download now is ONLY compatible with the latest version of D|S, not with yours.
    Open a help ticket and beg for an older version. Maybe you'll get lucky.
