Fixing "Could not find output property" warnings
So I'm starting to run into long G8F load times and the log file shows 20-30 wanings for missiing morphs, like:
2021-12-24 14:50:45.492 WARNING: ..\..\..\..\..\src\sdksource\fileinput\dzassetdaz.cpp(5759): Could not find output property for formula: Genesis8Female:/data/DAZ%203D/Genesis%208/Female/Morphs/DAZ%203D/Head/Old/PHMEyesIrisSize.dsf#PHMEyesIrisSize?value in file : /data/DAZ%203D/Genesis%208/Female/Morphs/vyktohria/Lydia/VYK%20Lydia%20Head.dsf
I've seen posts about manually editing the problem file to fix the warning, but none of them specify which file. Should I be editing PHMEyesIrisSize.dsf or VYK%20Lydia%20Head.dsf? Thanks.
    The message reads as: While reading ...\VYK%20Lydia%20Head.dsf, DS found a reference to a property it cannot find ...\PHMEyesIrisSize.dsf#PHMEyesIrisSize?value
    Problem is, you don't have PHMEyesIrisSize.dsf, or there is a typo/some other problem in one of the files.
  • BejaymacBejaymac Posts: 2,002
    Iirc PHMEyesIrisSize is part of the starter essentials, for some reason the vendor has moved the file(s) to a new location, a location the rest of us don't have.
    You would need to edit the formulas in Lydia head set and point the pathways to the correct location.
    Not at my pc so can't be more specific
  • barbultbarbult Posts: 27,479
    Submit a help request and tell Daz about the error. They should ifx it.That file path with "Old" in it is not a valid path for a product sold in the store.
