help with Iray Latitude/logitude
When I set the propper vallues for latitude longitude in the render settings and the set the time to say 11.00 the render turns black. what am i doing wrong? When I set the time to something like 07.00 the light seems right for my city at that time. Settig values in the tone mapping to make the lights brighter makes the sky go totaly white.
Have you checked the UTC Offset hrs in the field right below the one where you set the time?
It defaults to -6 hours of London Time, so you need to set it to your time zone to function properly.
Thank you very much. That did the trick. Thank you for making the learning curve less steep :-)
Thanks for the tip, I couldn't work this out yesterday so I just reset it to default.
Should be GMT 0.00 because we invented Time Zones. LOL
