* Released * Ultra Scenery Toolbox - Volume II
Totte
More tools to enhance your Ultra Scenery Experience are coming
1000 x 1300 - 467K
1000 x 1300 - 285K
1000 x 1300 - 212K
1000 x 1300 - 626K
1000 x 1300 - 265K
1000 x 1300 - 310K
Post edited by Totte on
Uh oh, my store credit just dug itself a foxhole and is hiding in there! Looks like another must-have for me.
.Okay, you got one customer
. To state a common internet meme: "Shut up and take my money".
So, how was those candle and skulls images done in UST-II?
Another must buy! My credit card has just screamed in terror, however. I will have to try and calm it down before this turns up in the shop.
It will be interesting to see what @barbult does with it!
Cheers,
Alex.
Totte gave me an early copy to test during development.
I found it to be very useful and fun to use.
First, be aware that I don't give a hoot about real world combinations of plants. I'll mix anything I want to! Palm trees in a pine forest - why not? Daffodils in a swamp - sounds good to me!
Here is the summary of one scene:
Note: As an alternative to deleting individual instances with Toolbox II, I could have used Toolbox I masks to clear out an area around my camera. But Toolbox II gives much finer control over what is removed. Both techniques are useful and can even be used in the same scene if you want to.
As usual, @barbult shows some super renders ;-)
"First, be aware that I don't give a hoot about real world combinations of plants. I'll mix anything I want to! Palm trees in a pine forest - why not? Daffodils in a swamp - sounds good to me!"
I entirely agree. Most of my renders are set in a vaguely Tolkienesq fantasy multiverse. As far as I'm concerned, Realism jumped out of the window, screaming in terror, the instant Fantasy walked in the door.
On a general note, will it be possible to export a custom ecology so that it can be shared with anyone else who has the necessary content files?
I love your final scene. In particular, the contrasts between the different species of tree.
Cheers,
Alex.
The Ecologies you create are "self contained" folders in the Ecologies Folder under UltraScenery (The names all start with UST ), so you could zip that up and send to someone who has all the needed things installed and it will work. You can as you see in the pictures create your own preview and thumb too.
I agree that it would work fine, but I have never shared ones I have "created", because I am concerned about the ethics and legality of doing that. The contents of the ecologies that I edit or combine are 99% pieces of store bought products. For example, HowieFarkes put a lot of work into creating UltraScenery ecologies for his older Mossy Hollow and Harpwood products. If I give away ecologies based on those with small tweaks, I am essentially redistributing his product. I don't think that is proper. He gave us permission to edit the purchased ecologies for our own use. I'm not aware that he has ever given permission to share those ecologies with other people.
You make a valid point. I assumed that Totte's product generated its own underlying code but if it recycles bits of the code from existing ecologies then there are both legal and moral implications.
Cheers,
Alex.
Thank you for understanding. Toolbox II lets you pick out layers of existing ecologies to combine together in new combinations. The code of the selected layers is essentially copied from one ecology to another. you can make tweaks to affinity settings, but most of the code is identical to the original layer, as I understand it. Toolbox II also has the capability to allow you to add in layers that you have coded yourself with a text editor. But even those layers are usually made by starting with an existing product layer and swapping in different props, so most of the code is still from the original product. I don't feel that I have any right to distribute those files. Also, in addition to possibly undermining the sales of existing ecologies, I think it would undermine sales of the toolbox itself. If somebody combines the layers for you, you have less incentive to buy the toolbox and do it yourself.
Now what I think would be OK, is to list what layers you copied from which product, and let other owners of the ecology products use the Toolbox themselves to perform the same layer combinations.
I can see that when you collaborate, like working together on a comic series or something, and more than one artist needs the same kind of ecology.
Like @barbult, I had the privilege to give UST II a spin. Unlike her, I'm just posting my renders without a breakdown
The renders consist of elements from 5 or so different ecologies.
@DoctorJellybean - very lush! I like all the colorful elements. I see lots of things I recognize, like apple trees from Tangy Apple Orchard, bromeliads from Mossy Hollow, Daffodils from Country Ford, etc.
Very nice render so far.
I was also allowed to test Totte's Toolbox II. Here I mixed some ecologies and added the trees with a script.
Here I mixed TA Dry Desert 02 + Desert Depression. https://www.daz3d.com/desert-depression
Here I built a palm tree ecology. Almost all trees were swapped and fish were added. Ok to change the horizon I have no idea. Maybe someone has a tip.
A mixture of different ecologies and cobblestone shaders (added by hand). Butterflies and toadstools with scripts added.
Somebody is having fun with Toolbox II
That happened to me before because the mushroom proportions didn't fit.
Great renders @Norman_R!
Thank you. Thank you for the tool. It's a lot of fun and I still have a lot of ideas. I also bought cheap again. For example bamboo
It is in the store already! https://www.daz3d.com/ultra-scenery-toolbox--volume-ii
...and Santa already put it in my cart
Best Christmas present ever! Another browser-scorchingly fast entry into my shopping cart.
After the last few weeks at work, I need a few days to unwind but I hope to start having my evil way with this product early next week.
Cheers,
Alex.
I love this! How did you add the cobblestone shader just to the road? Is it a separate material zone? I've never looked.
