Restore Translation Widget to G8 Figure
After applying a pose preset to a G8 female figure, the translation-rotation widget became separate from the figure. (See two image attachment showing before-and-after scenes.) It's pretty inconvenient to work with this figure from then on. Is there a way to reset or restore the widget to the newly-posed figure?
Thank you.
447 x 557 - 35K
1203 x 661 - 79K
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
  • csaacsaa Posts: 1,073
    @crdigit,
    Yes, I confirm that fixed the problem. Thanks so much for your help.
    Cheers!
    cridgit said:
    The hip has moved away from the figure's root (origin). Select the hip then enter 0, 0, 0 for position and it'll return to origin.
