How does one create prop blurs?
anthscoanthsco Posts: 19
Some aircraft models come with blurred props but some dont.
I know there is a motion blur in the render settings...how does one create prop blurs in Daz?
  • SimonJMSimonJM Posts: 6,074
    At the risk of sounding facetious you can use the Motion Blur setting. That pre-supposes the props permit rotation. If so, then it's a 'simple' matter of:
    Create scene.
    Go to Poses and put animate track onto frame 1.
    Rotate the prop(s) you wish to have motion blur - I'd recommend (as a vague rule of thumb) going for about 270 degrees
    Got back to frame 0
    In Render Settings, select advanced tab
    Check 'Motion Blur' and adjust Motions Samples and Motion Amount to acceptable values - and that's the trick, trying to find what is right. Again, as a wild vague guess try 4 or 6 Motion Samples and 75% Motion Amount.
    A tip here - use the Spot Render tool here to check what the settings will do. Rinse, repeat until looks good.
  • kaotkblisskaotkbliss Posts: 2,914
    edited March 2015
    My guess is the creator made a circle, then modeled in various positions of the propeller blade, then set different areas of the circle to different levels of opacity for the spinning/ghosting effect.
    *edit*
    spelling
    Post edited by kaotkbliss on
  • Richard HaseltineRichard Haseltine Posts: 108,758
    In general such things are a flat plane with a motion-blurred image and opacity map applied, either actual motion blur or just something painted to look like it.
    Ahh, hadn't thought of that route. Much simpler than modeling the whole thing. lol
  • LimunLimun Posts: 182
    Create scene.
    Got back to frame 0
    any idea how to do this in iRay Render Settings ?
    Thanks
  • srieschsriesch Posts: 4,243
    If the props that come with a model don't rotate, another option would be to hide them, then find a reasonable substitute stand-alone propeller model and add that one to the scene, which can then be rotated to get the prop blur.
  • SixDsSixDs Posts: 2,384
    Another alternative would be to kitbash and simply use the prop planes prepared for another model. You can scale as necessary, but may need to do some hunting to ensure that it is a two, three or four-bladed prop as the model requires.
  • I tried something different. I duplicated the prop, and changed the wight scale, then spun them. I selected them all, and brought down the opacity. Kindof worked, better than nothing
  • Limun said:
    Create scene.
    Got back to frame 0
    Thanks
    motion blur doesn't exist in this implementation of iray, but there is a script for it.
    http://www.daz3d.com/motion-blur-for-iray
    haven't tested it myself so i can't comment on it's useability.
  • DekeDeke Posts: 1,636
    I render in Iray and then add motion blur in After Effects with either CC Force Motion Blur or Pixel Motion Blur.
  • anthscoanthsco Posts: 19
    Many models already have propellors that hae been blurred and set up as props that can be parented to the model. Like the F4U duo in the render below. My question stemmed from having to create a prop blur in Daz from a motionless propellor without having to exit Daz. That was splendidly answered in the seond or third post. :)
    1366 x 768 - 1M
