Shader baker doesn't bake anything
I'm trying to export a shader https://www.daz3d.com/visual-style-shaders on a character I have, I select the surfaces I need to be baked, I set the image path, but when I hit the bake button it prompts me some process windows saying they're baking the selected surfaces. But when I go to the folder I see nothing. I tried with different shaders and still no textures files are in the folder.
  • BejaymacBejaymac Posts: 2,014
    First thing to be aware of is that the "Shader Baker" is 3Delight only.
    Second is that it only works "out the box" with the default shader, doesn't work with any of the other pre-compiled 3Delight shaders.
    Third is that it can be made to work with Shader Mixer shaders, but they need to have a "Baker" brick correctly connected to get anything, even then results can be more miss than hit.
