Body parts deform when trying to pose them
I am having an isuue where the body parts deform doing very simple position adjustments. In this case it's her fingers. Every dial was set to zero then I "Fingers in-out" and everything was fine. As soon as I touched the "Grasp" dial they fingers started to freak out and deform. This happens to her arms as well. Moving an arm slightly in any direction moves the whole shoulder and the arm often starts freaking and twists shoulder into spaghetti. This is only happening to this character and has never happened before. I tried doing the position reset on her (by using the Genesis 8 default pose ). Could someone help me please? Thank You.
1339 x 988 - 1M
  • GordigGordig Posts: 10,805
    I would guess that you're using a character that hasn't had the rigging properly adjusted to shape. Zero out all shaping morphs and see if that's still happening.
    Thank you so much. I saved the current morph. Then reset her. Then loaded my saved shape and everything works fine now. Thanks a whole lot.
