Pose compatibility for Centaurs?
Sort of an odd question, I suspect, but I'm going to ask if there are any issues with using poses for Centaur 8 Male on Centaur 8 Female. I know that generally poses for G8M will work for G8F and visa-versa, but I'm curious if that carries over to the Centaurs.
  • Matt_CastleMatt_Castle Posts: 3,307
    edited December 2021
    My experience so far has been that G8M centaur poses and G7F centaur poses (as long as you've got one of the scripts/tools to correct the G7/G8 arm offset after loading) both work fine with G8F Centaur.
    G7M centaur poses don't however want to work on G8F centaur unless you edit the file contents.
    I presume the inverse is true for G8M centaur, but I've tested that less extensively.
    (This is, however, a little odd, as often Hierarchical presets can be pretty picky, so don't assume it works well for other things).
    Post edited by Matt_Castle on
  • Thanks Matt. That was kind of what I was suspecting mght be the case.
