Base Genesis missing.
ab_963ab_963 Posts: 4
Hey. I just installed David 5 character but it does not work properly because it seems that I am missing base Genesis. The error message was something like this:
Some asset needed to load the file were missing. The content may not work as expected. The following files could not be found: /data/DAZ 3D/Genesis/Base/Genesis.dsf
What should I do? Where can I find the base Genesis?
  • Scott LivingstonScott Livingston Posts: 4,352
    If you haven't done so, you'll need to install "Genesis Starter Essentials" (not to be confused with "Genesis 2 Starter Essentials"). You should already have it in your Product Library already, as it's bundled with DAZ Studio. You can install it using the Install Manager or download it from the website: https://www.daz3d.com/downloader/customer/files
  • ab_963ab_963 Posts: 4
    Thank you. It worked!
