Help with figures turning into blocks when i zoom
GlennFGlennF Posts: 143
Daz has been working fine until this morning. When I zoom, rotate, or pan all figures turn into blocks and stay that way till I stop then they go back to normal.Any help?
  • Steven-VSteven-V Posts: 727
    Let me see if I understand this.
    The figure looks normal. Then when you start moving around the camera in the editor, the figure deforms and looks blocky. Then when you let up on the mouse and stop moving the camera, the figure goes back to normal. Is that correct?
    Does anything else do it? Props? Trees? Desks? Things like that? Is it all generations of figures, or just Gen 5-6?
    It sounds like you have made a change to the Tool Settings.
    Go to Window > Panes (Tabs) > Tool Settings, and look for During Manipulation near the bottom of the pane, and set the Draw Style to 'Use Current (Off)' that should fix it.
  • GlennFGlennF Posts: 143
    Thanks JimmyC that did it.
  • Testing6790Testing6790 Posts: 1,091
    That happened to me once and I thought it was hilarious. I was like, "So this is a feature I guess."
    Yea
    I was attempting to play with the deformers and boom this happened.
  • Subtropic PixelSubtropic Pixel Posts: 2,403
    Indeed it is a feature. It's intended for slower graphic cards; keeps the UI working smoothly because the card doesn't have to spend all its time rendering the preview until you take your hand off the mouse.
